Commercial grade walk behind, Bunton. Company was bought by BobCat as I under stand now. It has a 44 or 48 inch deck, 14hp manual start Kohler engine and the reason it is now mine. I have had to work on it before to get it to start the former owner is a run them dry guy with nothing in the fuel. In every case I have had to remove the float bowl and free up the valve and seat which had the float stuck. I finally got him to use stabuil in it, but of course if a little (per the bottle label.) is good more is better. Then you incounter a sand like substance that clogs up the filter and valve in seat. He only used it a couple times a year since 2006 to mow paths along side the rented out field and thru the woods where he can't get his compact Ford and brush hog. I plan on useing it to mow along our new fence line. We finally got the last post set in place Thursday in the morning. Also will mow the paths thru the field the pups and i walk. Al
I checked the safety switch for the trans yesterday and it is working fine. Still don't know if I have spark at the plug yet, I really dislike my spark tester has to be nearly dark to see even a strong spark. Hum wonder how mad Kare would be if I had her hold the bare end of the spark plug wire? Al
If you go that route, we need the pics or it didn't happen. I've done that both intentionally as well as unintentionally. I am impatient, and if the sun won't let me see the spark, I know a surefire way to check. Edit.. that may explain a great many things
