My Five Year Plan - A Few Questions - Suggestions Welcome
Discussion in 'The Wood Pile' started by HarvestMan, Mar 23, 2015.
  1. HarvestMan
    HarvestMan
    Southeastern Michigan
    Hello Everyone,
    First post, been here some time reading and sending a few PMs to regulars regarding the stove I have on order.
    I have a Woodstock Fireview on order and would like to get five years ahead so that I am always burning properly seasoned wood. With my old Hearthstone Harvest I used about 3.5 cord each year. The Fv has about the same firebox size as the old Harvest, but I am pretty sure the Fv will be a bit easier on the wood. However, for my planning purposes I am going to assume I will need 3.5 cord each year for the new stove.
    I have two properties I can cut wood on (one only downed trees, the other anything dead). I also have a tree service that will provide me rounds < 18 inches at about $100 for 1.75 cords when split. When I first thought of getting 5 years ahead, I only thought about the quantity needed. After starting, my main concern is the first 2 years of wood supply. I have approximately 8 cords of wood currently, however, most of this wood is at the 20 - 24% MC and I am a bit concerned it may not be dry enough by next burning season. Most of my wood is red/white oak with a bit of black cherry and walnut.
    Hoping some experience can help me with a few questions:
    1) I started splitting some of my 20-24% wood down to 2-3 inch splits hoping to speed the drying process. Is this a reasonable strategy or a fools errand?
    2) I have access to dead standing elm and cherry. Should I try to load up on this now and get it css and plan on using this for the upcoming season?
    3) Got tons of OLD dead and down white oak that I am currently working on; much of this is < 25%. Is it reasonable to expect any of it to be ready by next burning season if css in the next month?
    Here are some pictures of what I currently have and some stuff still in the woods.
    Last picture is some red oak from the tree service - not going to be ready for quite a while - will be re-stacking shortly as this was stacked close only to know cords in load.
    Thanks
    3232015 368.JPG 3232015 369.JPG 3232015 371.JPG 3232015 351.JPG 3232015 353.JPG 3232015 322.JPG
    Gark, Stinny, milleo and 24 others like this.
  2. swags
    swags Moderator
    You have a great start, if it was me I would go for the cherry for the first 1-2 year supply. That dries fast and is an easy wood to process. Can't beat the oak for btu but the cherry will dry in less then half the time the oak dries. I'm on a three year plan and it's working out pretty well for me. Every year since I started that I enjoy burning the drier wood even more.
    Drvn4wood, Stinny, splitoak and 10 others like this.
  3. papadave
    Backwoods Savage would have some very good info for you on that stove as he's had one for several years now.
    Dennis, where ya at?
    My initial thought would be that splitting that small might not be your best option, as the wood will burn more quickly. In the Fireview, that might not be the case, so.....I'll defer to Dennis or anyone else with that stove.
    Nice stash so far. Lived in SE Mi most of my life, until a few years ago.
  4. fox9988
    fox9988
    NW Arkansas 72717
    Welcome HarvestMan :handshake:
    You showed up with a great plan in motion. My first year with the Keystone, I burned Red Oak at ~25% and didn't have any problems. But its gotten better year by year. Splitting the wood down to a smaller size will speed drying. The dead standing cherry should be in good shape by next winter if you css (cut,split,stack) it soon. You're gonna love the FV.
  5. Eric VW
    Hey there HarvestMan,
    Welcome to ya, and what a start- you got three heavy hittin responses right off the bat!
    Nice stacks, post up the new additions as you go...
    Uhhhmmmm, you might consider the thrown together solar kiln, and see if it can turn some of that oak around by next heating season- just throwin that out there. Be sure to do a marked control piece outside of the kiln and a marked piece inside. Either use a moisture meter or a scale- even a bathroom scale, with you on it holding your wood:rofl: :lol:!
    Eric VW
    Sam, sherwood, Shawn Curry and 3 others like this.
  6. Horkn
    Welcome to FHC!
    I'm working on my multi year plan too. I've been cutting dead standing elm, cherry, hickory, and sugar maple this fall and winter to get my hoard at least 2 years out this year. I've also cut some live, but needing to be taken down beech, hickory, and other trees like box elder and cherry that dry in a a summer.
    If you have 8 cords at 20-24% already, you'll be fine. A summer of heat and air will get the ones at the high end under 20%. Of you can, save the oak for 2016/17 or later, that stuff takes a long time to dry.
    Dead, standing cherry, and elm will be ready easily for next year if css'd this spring. , fresh cut maple, box elder, ash would all be ready for next year.
    I'd say you'll be fine. A lot of you oak will be ready too if it's at 25% now. A summer will go a long way to season that.
    Resplitting stuff at 20-24% is a waste of time. You've got a long time to get it to drop even more. It's already a long way into seasoning if it was oak.
    If you want to expedite the process, a solar kiln apparently will get the Mc much lower than air drying alone. I'll be trying at least 1 Augie style kiln and a control stack from the same tree for scientific purposes.
    mike bayerl, milleo, sherwood and 6 others like this.
  7. Paul bunion
    Paul bunion
    I think you are going to be just fine with the 20-24% wood after another summer. (If you are targeting 20% at the wettest.) Keep the rain off it and you'll be there or beyond without issue.
  8. HarvestMan
    HarvestMan
    Yep, I'm going to load up on the elm and cherry. I have a real love/hate relationship going with elm - love that it is usually ready to burn but hate when I need to split it with my x27. I'm going to plan to burn the dead standing and hope for a good summer for drying with the rest.
  9. HarvestMan
    HarvestMan
    I have never tried the solar kiln setup for wood drying, but I think I will give it a shot on at least one of my stacks to see how it works out. Normally, I have all my stacks covered - I did take off the tarps the last couple days as we were not scheduled to have any rain. Looking to establish a better cover than tarps in the near future.
    Right now I am in the process of "re-doing" my whole storage area so it is a bit of a mess. Will post more pictures as I get all my new pallets set up and start to fill them with wood.
    I really want to get far ahead so that I don't get this "uneasy" feeling each year wondering if my wood is going to sufficiently dry ... kind of weird, go through this just about every year, but I am finally getting organized to eliminate the concern. Also, getting the new stove makes me want to make sure I only feed it the good stuff.
  10. Pyroholic
    Pyroholic
    mid michigan
    You've got a good plan and have some good advice already. All I have to add is welcome from another SE Michigander.
    sherwood, Chvymn99, wildwest and 2 others like this.
  11. Fanatical1
    Fanatical1
    I hear you about hand splitting the elm! :picard: Red elm splits a lot easier though than American elm. Might be a good excuse to buy a splitter? :whistle:
    I'm sure you will find some dead standing or leaners near the ground that will be good to go this year and next. I just cut a small dead standing maple and red oak that were both under 20%. Top covering would help some also. That moisture meter will be a good tool for you while you figure out how everything is drying for you this year and next. Some of that oak might be ready a little sooner especially if it was dead standing and you keep it stacked well and dry. Sun is helpful too. Your stacking looks great by the way.
    As others have said, cut the wood this year that will dry the quickest since you already have a lot of oak cut. Dead standing or leaners, cherry, ash, pine etc.. Keep your oak drying for a couple more years and cut double your yearly usage for a few years and your ready to go. :)
    And welcome to the forum! Keep posting the pics! Your wood stacks look great by the way. :yes:
  12. Horkn
    Same here with elm for me. I find it dulls chains faster than any other wood I've cut as well.
    I don't have a splitter yet, but I get to use one sporadically. I save the elm for splitting with the hydraulics. My 6lb maul just bounces off all the american elm we have.
    The dead standing elm sure allows me to get ahead, and was about half my wood this year. Love it, but hate it. It burns really well, my wife and I like how it smells. It's not pizz elm. That's red elm, and apparently it stinks. American elm is a different smell.
  13. Chvymn99
    Welcome HarvestMan ! Sound advise that you've recieved. Cherry & Walnut if exposed in the right condition and CSS right away should be ready to go by burn season. I like my Walnut. :thumbs:... 20-24% moisture should be achievable for late December/January/February where you'll be needing those valuable BTU's anyways. You can think about smaller splits for this year & next but from then you should be set.
  14. Shawn Curry
    Shawn Curry
    Western NY
    20-24% is pretty close, and with cherry and walnut you'll be ready to go next year for sure.
    Check the insides of a fresh split to confirm the reading, unnecessary if they're already that dry.
    Yes, yes, and yes. Too much is always enough. In spite of what some might tell you, wood wont rot if it "sits too long", if you're keeping it dry anyway.
    It looks like you're off to a great start - I think you'll fit right in! Welcome to the club! :handshake:
    [EDIT] Standing dead elm, once it's good and dry, bark falling off, radial crack running up the trunk, is ready to split. It will give right up to the x27 when its that dry. And it's ready to burn right away too!
  15. TurboDiesel
    Welcome Harvestman
    You've come to the right place.
    I think your plan is good. The oak you might save till later, but you burn what you have. The Fireview is a great little stove. You won't be disappointed.
    And of coarse...keep the pics coming;)
  16. Knothead
    Knothead
    East Texas
    :campfire:Hello and Welcome HarvestMan, just started here myself. Its a great place for information into the hobby. Love the pics,keep them coming.
  17. wildwest
    Wyoming high plains
    I have not seen him today either.
    Backwoods Savage, sherwood and Horkn like this.
  18. Wisconsin Woody
    Wisconsin Woody
    Cecil, WI
    Welcome Harvestman - you will really enjoy the Woodstock stove. You've got a great start on your wood supply plan!
  19. swags
    swags Moderator
    HarvestMan if your looking for a little different method then tarps to keep wood dry look into a carport. They are inexpensive and can keep a lot of wood dry.
  20. sherwood
    sherwood
    Great looking stacks, and great advice.
    A word of caution: if you are used to a front loader, a Fireview has a SMALL door.
    16 or 18 inch lengths will work with the Fireview. Large rounds and splits will not be easy to load, too large won't go through the door. Weird shape uglies can be a challenge too. Thought it doesn't look like you have too many of those. Maybe someone else with a Fireview will measure the inside opening dimensions for you. Because I am starting seeds at the moment, I cannot get to my stove (not in use at this time) to do so.
    That said, you do want decent size splits and rounds so you will get nice long overnight burns on the coldest nights. As long as it will go through the door, a large split or round in the bottom back is great for a very cold night. Then load the rest of the stove. I would not worry too much about resplitting the wood that is already at 24%. It should be fine even at that moisture content, and definitely will be OK by Autumn. Better to spend your time cutting some more wood. You could certainly cut some of the cherry into smaller splits to burn along with your already seasoned wood. The woods that dry quickly will be good and dry for the coming season if split small now.
    The Fireview is an easy stove to run. Fires start pretty easily. As well as long cat burns, you get beautiful secondary displays with the Fireview.
    I know you'll love your stove. Such an easy stove to run and maintain, such a terrific workhorse, such nice, gentle heat, so miserly in wood consumption, and very pretty to boot.
    Congratulations, and enjoy!
