Momma Bear, Added baffle today, and moved vent pipe to top, pictures:
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by Lastmohecken, Aug 23, 2021.
  1. Lastmohecken
    Lastmohecken
    Arkansas
    I got bored today, and decided to make the conversion to top vent, and added a removable baffle out of half inch thick plate. Almost done, still need to patch up the back hole, and weld the pipe in the top plate, but I have the pipe all cleaned up and fitted in the top, just need to weld it in.
    MAMA BEAR STOVE 2.jpg MAMA BEAR STOVE 3  BAFFLE.jpg MAMA BEAR STOVE 3.jpg MAMA BEAR STOVE 5 BAFFLE.jpg Mama Bear Stove.jpg
  2. Eric VW
    Wouldn’t it be something to add a chunk of stainless pipe, predrilled with outlet holes, running side to side beneath that baffle.... not saying you should do this, but just sayin’....
  3. Lastmohecken
    Lastmohecken
    Arkansas
    That's a 10" wide baffle plate, on about a 45 degree angle. I didn't choke it off as much as I probably could have. Should I put any small holes in the bottom area of that baffle or do you think I am good as is? I was going to use 3/8" thick plate but all I could find today was 1/2" thick. It shouldn't warp much, anyway.
  4. Lastmohecken
    Lastmohecken
    Arkansas
    Interesting; Would that smoke? I have heard of doing that, but I am not sure I understand the concept. Or are the holes just in the end of the pipe? I guess I need to see a sketch or picture or something to understand exactly what's happening.
  5. Eric VW
    Pre drilled in the fashion of epa tube stove secondary air tubes... introducing preheated air to the fire, above the load.
  6. Lastmohecken
    Lastmohecken
    Arkansas
    Sounds like a good idea, but I guess I have not really paid much attention to any stoves like that. I am sure I could do it, if I seen an example, or something to follow.
  7. Eric VW
    Just search out any epa tube stove here on FHC or the ‘net.
    You’ll see what I’m talkin’ ‘bout.
    :yes:
  8. Lastmohecken
    Lastmohecken
    Arkansas
    Ok, thanks
  9. Eric VW
    :yes:
    So, if you can’t easily see what I’m talking about, think about the burners within a gas grill... they might be a straight run pipe or curve around to form sort of a capital “D” shape... and lined along one axis with holes, from which propane normal flows out of... just change propane for air in a wood stove.
    You might include “secondaries” in your search. :salute:
  10. Lastmohecken
    Lastmohecken
    Arkansas
    Ok, I watched a few videos of secondary air tubes. I get it, now, how they work. It looks like there is lots of experimenting going on, and lots of variations out there. I do see how I could do a simple pipe with holes and a damper on the end to regulate the outside air going in. I don't know if I need to take it that far for the occasional use in the shop, but I might just for the heck of it. With a damper I could always just shut if off if I didn't like it.
    I would like to start with a schedule 80 stainless pipe or heavy wall square tube so it would last, and I can get that where I used to work. I might give it a try.
  11. Born2Burn
    Born2Burn
    Youngstown, OH
    I'm in no hurry but I will be building a custom baffle for my Momma Bear here before the cold hits too. I'm no fab expert but I do have a welder and a good source for materials.
    For mine, I'm thinking of either making the "shelf" out angle iron that will hold fire 6-8 bricks, OR, using the steel plate as shown above and putting a ceramic board or blanket on top. I don't know if either of there are beneficial but I know that secondary burn stoves (in addition to the secondary tubes) always have the overhead ceramic to hold the heat down.
    I really like the idea of installing secondary burn tubes but that is likely out of the ballpark for me. A good smoke shelf should be all I need. Then, I just need WelderDave to learn me on how to operate this unit
  12. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    You can do it. ESW has a hole pattern for the NC-30 on the spec. sheets. I did it for my old Timberline and it was worth the effort.
  13. PA Mountain Man
    PA Mountain Man
    Lisburn, PA
    Our hunting cabin has a Grandma Bear that has been abused for 40 years. Several years ago a member pointed out that a baffle would increase heat output and burn times.
    After doing some research and finding Coaly , I installed a baffle last year. I didn't follow Coaly's plans exactly.
    I used the firebrick trick on the sides to support 3 pieces of heavy 4" x 1.5" channel. Now the front top gets much hotter than the back and we are burning less wood with more heat.
    I don't know percentage but now, after the poker game and other shenanigans:rootintootin:, the fire lasts until coffee:coffee: in the morning and the cabin stays warm.:banana:
    Working on a way easily install a secondary air system...
  14. Eric VW
    Consider installing a chooch valve so you can adjust the amount of secondary air.
    :yes:
  15. PA Mountain Man
    PA Mountain Man
    Lisburn, PA
    that's on the drawin board
  16. Eric VW
    :salute:
  17. Lastmohecken
    Lastmohecken
    Arkansas
    Yep, I would think that would be a must do thing.
  18. WeldrDave
    Beautiful!!! :tears::yes: Job!!!
    metalcuttr likes this.
  19. WeldrDave
    I Just bought another Mama Bear stove this morning, it's a 1981 with 25ft of heavy Insulated double wall Selkirk Pipe, $350.00. This will eventually be my shop stove...
  20. brenndatomu
    Geez...buy the pipe at half price and get a free stove! :jaw: can't beat this deal with a stick! :deadhorse:
