Modified Log Tongs
Discussion in 'Axes, Mauls, and Hand Saws' started by buzz-saw, Mar 18, 2021.
  1. buzz-saw
    buzz-saw
    Ct.
    Here are a couple pictures of a set of Husky 12 inch log tongs I modified for use with my splitter. Converted to 4 points instead of just two , this way I am able to hold smaller logs level and centered on the 4 way wedge if tongs are not centered on the log.
    I tried using the way the were to hold logs off the beam but problem I was having was if tongs were not at the perfect balance point the log would tilt one way or another.
    Works great around the splitter.
    I won't use this pair in the field any more. I did this just for splitting. Log Tongs 1 copy (2).JPG Log Tongs 2 copy (2).JPG
  2. sirbuildalot
    sirbuildalot
    Mass
    Looks nice! Good job on the fabrication! They definitely don't work the best on small pieces.
    Screwloose, Eric VW and buzz-saw like this.
  3. buZZsaw BRAD
    FHC engineering at its finest. :thumbs: What size are those?
  4. buzz-saw
    buzz-saw
    Ct.
    They are the 12 inch.
    I did loose a little by adding the extra points , now between the points is probably around 10 inches.
    But since I am just using with the splitter that is fine , any log larger than what they can grab I can just let it sit directly on the beam.
  5. Ronaldo
    Ronaldo
    Very nice fabrication and welding skills. Looks quite neat and works well, I'll bet.
  6. brenndatomu
    So what's the advantage of using the tongs to hold the log on the splitter...just keeping your hands out of harms way?
    Screwloose, MikeInMa and Eric VW like this.
  7. buzz-saw
    buzz-saw
    Ct.
    If I am running the 4 way wedge and have a smaller log the position of the wings on the side of the wedge with the logs sitting on the beam will give me 2 larger splits off the bottom of the wing and two smaller off the top of the wing. By holding the log off the beam I can center it on the 4 way wedge. This allows me to easily hold up the log with one hand and use the other hand to operate the splitter.
  8. brenndatomu
    :yes:
    Eric VW, buZZsaw BRAD and buzz-saw like this.
  9. cnice_37
    cnice_37
    Very smart, looks like great fab work
  10. Paul bunion
    Paul bunion
    Did you try it out with only one side done as a tripod arrangement?
    SKEETER McCLUSKEY and Eric VW like this.
  11. buzz-saw
    buzz-saw
    Ct.
    No I did not.
    I figured that two sets almost directly across from each other was my best bet in keeping logs level.
    Don't know Maybe 3 would work ? But I know that 4 do work.
  12. eatonpcat
    Figures a known finger destroyer would ask this question!! :cool:
    brenndatomu and walt like this.
  13. brenndatomu
    I have a purple fingernail right now...its the middle one...wanna see it? :whistle: :D
    eatonpcat, MikeInMa and mrfancyplants like this.
