Metal in wood
Discussion in 'The Wood Pile' started by OhioStihl, Dec 30, 2018.
  1. OhioStihl
    OhioStihl
    Southern Ohio
    I have read on the forum about metal in trees turning wood black or blue. While I was cutting the Red Oak I put the saw on the stump to sharpen the chain. I went back the next day and this was on the stump. Just from the shavings it turn black quick.
    I also noticed that the splits have a dark edge where the maul contacted the wood. I have noticed this more with Oak than Ash or Maple.
  2. NYCountry
    NYCountry
    Mohegan Lake NY
    You never know what your going to find in wood
  3. amateur cutter
    IME Oak shows color the fastest. I've seen exactly what you are. Even the smallest amount of metal will usually give a bluish color overnight. No idea why Oak is so much more prone to this.
  4. MikeInMa
    I see the blue hue often, when using wedges to split red oak.
  5. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Tannins in the wet oak react with iron.
    It is a good indicator when cutting that something bad is about to happen to your chain.
  6. billb3
    supposedly it is the tannic acid
    If you handle a lot of wet red oak splits and get the tannins coated on the palms of your hands pretty good and then handle some bare steel the palm of your hands can turn black
  7. Chvymn99
    Was splitting wood this afternoon and found a blue streak in my oak. Next split I found out why... Had a screw and a nail in it...
  8. BigPapi
    BigPapi
    The hills of Western MA
    Much better to find with the splitter than the saw!
  9. Hatchetdancer
    Hatchetdancer
    I found a piece of 1/2” round bar halfway into a huge corkscrew willow. Just glad it wasn’t my saw. Backhoe finished the stump after that
  10. amateur cutter
    This I've known for a long time.
    This I just learned. Thanks fellas.
  11. mike bayerl
    mike bayerl
    Most of the time iron stain in wood is black/blue. This is because it is mostly Fe2+. Fe3+ oxides are orange/brown like rust, but I've never seen that yet. Must have to do with the redox contions in the wood
  12. T.Jeff Veal
    Yes, it's the tannic acid in the oak. I have seen it after 10-15 minutes when using a steel wedge to fall a tree.
    Backwoods Savage and Chvymn99 like this.
  13. T.Jeff Veal
    I found this in a huge round that a tree service cut with the splitter. Lucky they didn't hit it. IMG_20151110_124808713.jpg
    This log on the trailer was a line fence tree. Had 3 strands of barb wire in it. IMG_20170224_130306407.jpg
    Backwoods Savage, Felter and Chvymn99 like this.
