I know posts are 'useless' without prices and pictures. However, I have a long list of bits & pieces for a Stihl MS441 and it would just be too tedious to price every part and take photos. I'll list everything I have and a note if there's anything to mention. If you're interested in anything PM me letting me know what you're interested in, whether you'd like a photo, and a zip code it would be shipping to and I'll provide a price shipped to your door. Tank housing (decent condition; used, but not broken or too beat up) Brake handle (cracked, but functional if that's all you need) Crank Wrist pin needle cage Muffler (dented & a little rough, but functional) - SOLD (2) White plastic carburetor housings (one is from a model with heating and has the switch installed) Set of throttle/lock parts Chain tensioner Base gasket (metal) Both spring AV mounts that attach tank housing to case Plastic chain brake mechanism cover Both foam 'stop buffers' for case where pegs on tank housing nest- SOLD (2) flywheels Aluminum lower right tank housing corner guard Large cover washer (goes between worm gear & clutch) Complete recoil assembly (inner plastic shroud is loose from fan cover)- SOLD (2) black plastic carburetor brackets & misc. parts (2) carburetors (one is the heated version) (2) intake boots Decompression valve Spring AV mount that connects wrap handle to cylinder- SOLD (2) switch shafts Contact spring rubber carb grommet for heated saw w/ switch hold "Pre Separator" - the black plastic pieces that mounts just above the coil Bucking spike 1/2 Wrap handle (slightly bent at left side 90-degree angle; possibly could be bent back to proper shape) I'm sure there are a few more odds & ends (mostly small stuff) I haven't mentioned, so feel free to ask. I also have a set of orange plastics and two 1/2 wrap handles, but they're tentatively called for - I'll post if they become available. Thanks!
Absolutely no sweat. I know how it goes. I worked all day at my day job then cleared snow until 10:30 last night. Winter is here with a vengeance!
