Looking for a backup saw
Discussion in 'Chainsaws and Power Equipment' started by Dvscott, Sep 9, 2019.
  1. Dvscott
    Dvscott
    Pittsburgh, pa
    I have a stihl 311 with an 18" bar on it. Used my saws for cutting firewood. Looking for a solid backup saw incase my 311 goes down. Thinking i want something a little smaller with a 16" bar. Also wanting to stick with stihl. Looking to spend no more than $400.
    Sent from my SM-G892A using Tapatalk
  2. Eric VW
    If you’re looking for new, the MS 250 or 251 sounds like it’ll do fine by you. :yes:
    M2theB, T.Jeff Veal, Chvymn99 and 6 others like this.
  3. The Wood Wolverine
    Only one back-up? :whistle:
  4. Dvscott
    Dvscott
    Pittsburgh, pa
    The stihl guy was trying to sell me on the 250...he loves his....anyone else have experience with the 250?
    M2theB, T.Jeff Veal, Chvymn99 and 2 others like this.
  5. ThomH123
    ThomH123
    East Granby
    MS 250 with a 16” bar running .325 yellow Stihl chain would be a good choice.
    Sent from my iPad using Tapatalk
    T.Jeff Veal, Chvymn99, Hammy and 2 others like this.
  6. ThomH123
    ThomH123
    East Granby
    MS 250 is my main saw. I run it with the 18” bar and the Stihl yellow chain. I had it a little over 4 years and I’ve probably put 14 gallons of fuel through it. No real problems. I try to clean it good after each use and I drain the fuel and run it out.
    I have abused it some, cutting dirty wood etc. I cut some 16” black locus rounds with it, stumps close to the ground etc.
    M2theB, T.Jeff Veal, Chvymn99 and 3 others like this.
  7. Slacker
    Slacker
    Durham NC
    If you can find a used MS261C you will be a very happy camper. It's a pleasure to use. I upgraded from a MS250 and im still kicking myself in the azz for not doing it sooner.
    It's a 50cc pro grade saw and it will cut more wood faster than the MS250 ever dreamed of.
    MFMc., M2theB, T.Jeff Veal and 6 others like this.
  8. Dvscott
    Dvscott
    Pittsburgh, pa
    Does it seem to bog down much? I will have a 16" bar on mine if thats what i go with
  9. Dvscott
    Dvscott
    Pittsburgh, pa
    How is the 261 weight wise?
  10. Slacker
    Slacker
    Durham NC
    10.8lbs powerhead only.
    The antivibe system is great, sips fuel and it's twice the saw my MS250 was.
    I get the same amount of wood cut in much less time.
  11. Dvscott
    Dvscott
    Pittsburgh, pa
    I was looking at a 026...buying used saws scares me but would love to have one
    M2theB, T.Jeff Veal, Chvymn99 and 4 others like this.
  12. Yawner
    Yawner
    Louisiana
    I have an 026 and love it. I look at want ads constantly, partly for entertainment. I see plenty of 026 saws for sale and plenty are in great condition, like mine was when I bought it used. If the budget could swing it, I would buy a 261cm. Those can also be found used, just not as many. I would say that the 261cm (yes, with mtronic) has about as good a reputation of any saw I've seen in the numerous forums I am on. People just love that saw and more experienced saw people, not less, say good things about the mtronic 261.
    MFMc., M2theB, T.Jeff Veal and 4 others like this.
  13. amateur cutter
    Hahahaha! Perfect response for someone with CAD.
    To the op, 261CM is a very good saw, we got my son one for his birthday last year & he easily makes all his firewood with it. Nothing against a 250/251, they're good saws, but not in the same league as the pro saw. I've got two 026's that I'd use over the 250 just for production purposes.
    MFMc., M2theB, RabbleRouser and 6 others like this.
  14. Dvscott
    Dvscott
    Pittsburgh, pa
    If i were to get a new 261...what are the different models and what do you guy recommend?
  15. amateur cutter
    MS 261 CM with 16 or 18" .325 full chisel chain & I'll guarantee a smile on your face. Then after the warranty expires send it out for a nice woods port & you'll soon be headed down the rabbit hole of cad like some of the rest of us.:D
    I am serious about the first part though.
  16. amateur cutter
    Hammy and Chvymn99 like this.
  17. Dvscott
    Dvscott
    Pittsburgh, pa
    Awesome....you guys have me leaning towards the 261...even tho its more money. Is a 16" bar good for it...not to small?
  18. amateur cutter
    I would say yes to 16" since you have the bigger saw available. I'll bet you'll find the 261 becomes the "go too" saw.
    T.Jeff Veal, Hammy and Chvymn99 like this.
  19. Yawner
    Yawner
    Louisiana
    I would say 16 inch and I am a fan of porting. If u do that, go 18 inch. U will luv 261cm I think.
    Sent from my SM-G960U using Tapatalk
    M2theB, T.Jeff Veal, Slacker and 3 others like this.
  20. Fifelaker
    Fifelaker
    Fife Lake Mi.
    My vote is either a MS261 or a ported 026 with .325 16" either will run circles around the 311, 026/261 ported is a different animal altogether. Ported = bigger grin.
