Long time, first time...
Discussion in 'The Wood Pile' started by Josh S, Apr 24, 2022.
  1. Josh S
    Josh S
    Massachusetts
    Listener that is. I have a question for the group. Today as I was bucking a downed ash tree, my saw would bog down and/or jump abruptly in the cut. This has happened from time to time before, but I just bought a new stihl 400 and the increase in power from my only other saw, stihl 291, made the jumping and kicking way more jarring to me. The culprit seemed to be that the cut was not straight. I just put a new (out of the box) chain on the bar so I suppose a dull chain can be ruled out (it's a green safety chain, fyi). The chain tension seems fine. I am using a 25 inch bar and the tree is just a bit wider than the bar. I'm using a wedge, so the bar isn't being pinched. I have cut larger diameter trees with the 291 and I am not doing anything differently. Perhaps there was some user error when I put the chain on the bar? I don't know. Before I looked around online, I figured I would ask here and see if there is a common answer. Thanks! I'll hang up and listen to your answer.
  2. Chud
    Chud
    NC
    If the 400 is having the problem with a 25” bar have you turned bar oil output to max?
    Another culprit could be the bar. Do you have another bar to use?
  3. Josh S
    Josh S
    Massachusetts
    I don't have another bar, but maybe this is a good excuse to get a light bar. I'll look into the bar oil setting. Thanks!
  4. The Wood Wolverine
  5. brenndatomu
    Its possible (but not typical) that having the tip of the bar buried is giving you some kickback...dangerous!
  6. Josh S
    Josh S
    Massachusetts
    This bar in new/came with the saw. Thanks for the link, I will check it out!
  7. Josh S
    Josh S
    Massachusetts
    I'm thinking that is part of the problem. I would try and cut from the other side of the log and, because the first cut wasn't straight, the bar would not sit well in the cut.
  8. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Try to take your saw over the top, and the tip down near the dirt on the back side and work back so the tip isn’t buried against uncut wood. Sharp chains bite a little!!
  9. buZZsaw BRAD
    This.^
  10. Hinerman
    Hinerman
    NE Oklahoma
    Semi-chisel or full chisel chain? My first thought was semi-chisel causes what you are talking about sometimes
  11. isaaccarlson
    isaaccarlson
    Colfax, WI
    like this
  12. buZZsaw BRAD
    Could it be an adjustment to a more powerful saw on your part as well??? Not sure on why it would cut crooked with a new bar & chain?
    I ran a 290 (precursor to the 291) as my only saw for years. Few years ago i got an MS460 (77cc). Going from a 16 bar to a 28" bar i felt like a professional logger. Took me a while to get used to the bigger saw and its power.
  13. Canadian border VT
    I agree with others above, other point is the green safety chain limiting chip bite and removal?
    I’ve never buried the tip on such chain
    metalcuttr, T.Jeff Veal and Josh S like this.
  14. buzz-saw
    buzz-saw
    Ct.
    Green safety chain buried fully could be the problem.
    That green chain has the bumpers under the front of the rakers and when that chain rolls over the nose it blocks the cutter from contacting the wood to prevent kickback.
    You can file down the bumpers to basically make it into a yellow link chain. I just did this to the chain that came with my 400. Why they sell a saw that is a pro saw with this chain is beyond me
  15. isaaccarlson
    isaaccarlson
    Colfax, WI
    I have bought green chain when no yellow was in stock. I take it to my belt grinder and in about 5 minutes you would never know it was green,
    I take the humps right down to the links. Green chain is yellow chain with "bumpers" that's the only difference. Sometimes I get bored and grind the rivets too...
  16. Josh S
    Josh S
    Massachusetts
    Yes. This is a semi chisel chain.
  17. Josh S
    Josh S
    Massachusetts
    Thanks for the visual. Very helpful.
  18. Josh S
    Josh S
    Massachusetts
    Thanks for the help, everyone. I appreciate it. I have learned a lot just from reading posts on this forum for the past few years. Not only has the site been really informative, but it has also motivated me to actively look for my firewood. I started reading 2 years ago and have got myself on to the 3 year plan (or will be when these two ash trees are processed), burning approximately 5 cords a year. Thanks again.
  19. Hinerman
    Hinerman
    NE Oklahoma
    Semi-chisel is horrible imo. It doesn't cut, it tears imo; even worse with the bar completely buried. Try a fresh loop of full chisel or square filed chain and report back.
  20. isaaccarlson
    isaaccarlson
    Colfax, WI
    semi chisel isn't THAT bad. It is definitely slower.
    Hinerman, metalcuttr and T.Jeff Veal like this.
