  1. Devin86
    Devin86
    Shinnston, WV
    I am running a new 55-TRP10 and I have a OAK kit installed short straight run and used a complete 3" pipe kit single pc thru the wall to a clean out and the rest up the wall with a cap. I am using Hammers pellets and below is what I have been getting this is after a complete clean and then about a 24hr run on 9 and 9 used about 60-70lbs of pellets.
    Low Fuel Feed 6
    Low Burn Air 4
    Air on Temp 1
    Anyone see anything wrong with these settings? The ash seems hard have been breaking it up and scraping it out with a small chisel and glass is so dirty you can hardly see thru it.
  2. slvrblkk
    slvrblkk
    Northampton, PA
    Those Hamers are a dense pellet....you might need to crank up your LBA a little and get more air going through your pot or cut down you pellet feed rate.
    gbreda likes this.
  3. Devin86
    Devin86
    Shinnston, WV
    Maby down one on the low feed and up one on the air?
  4. slvrblkk
    slvrblkk
    Northampton, PA
    Yup....that's a good place to start....
  5. slvrblkk
    slvrblkk
    Northampton, PA
    Do you remove ash out of your pot once or twice a day as the stove is running? Just open the door quickly and pull the ash?
  6. Devin86
    Devin86
    Shinnston, WV
    I have been shutting down once a day cleaning the ash tray under it around the oak and the door glass. I will try from now on as it is running never thought to do it like that should the ash be making its self into like hard cookies?
  7. slvrblkk
    slvrblkk
    Northampton, PA
    I used to pull the ash out like (opening door while running...quickly) that when I had my pdvc.....no, your ash really shouldn't be like that but that type of burnpot design are a little less forgiving with stuff like that. You getting good heat out of it?
  8. Devin86
    Devin86
    Shinnston, WV
    Heat seems a little weak to me but I have never had a pellet stove to compare it to. Just started it back up with the adjusted settings so we will see.
  9. slvrblkk
    slvrblkk
    Northampton, PA
    I typically ran my pdvc on 5-9-1 (depending on the pellet)....but that was me. Too high of LBA and you're sending heat out the vent but that seemed to work best for me.
  10. Devin86
    Devin86
    Shinnston, WV
    Set mine at 5-6-1 will report back tomorrow. Hope it works better
  11. slvrblkk
    slvrblkk
    Northampton, PA
    hopefully....you still might need to mess with it but thats a good start....
  12. DexterDay
    DexterDay Administrator
    Northeast Oh
    The ash color looks good. Could be a little lighter (white/grey), but not bad at all. Running on 9-9 with those settings your gonna burn some pellets, so you can expect some Ash and your glass to be dirty.
    Raising the LBA will help expell some more from the pit, along with increase burn temps, but as noted by Slvrblkk, it will also send heat out the flue faster. Which means less exchange time. It's a fine line between a bad burn and to good of a burn!
    slvrblkk likes this.
  13. imacman
    imacman
    Denver, NC
    Try 4-6-1 on the bottom buttons
  14. imacman
    imacman
    Denver, NC
    If you're comparing the pellet stove output to a wood stove.....don't. Wood stove puts out way more.
  15. eatonpcat
    I dated a girl in high school that we should have called Wood Stove!!
    IHATEPROPANE and smoke show like this.
  16. Woodporn
    Woodporn
    S. MA
    Just curious, why you're running 9-9? Is the heat output that weak?
    As Imac stated, try 4-6-1, on my pdvc I run 4-5-1 but everything changes from stove to stove.
  17. imacman
    imacman
    Denver, NC
    Don't know if the OP is running on a stat or not....if he is, the 9-9 is correct, according to the owners manual.
    Otherwise, he has indicated in the past that the house is "poorly insulated". Also, is the stove in the main living area, or in a basement?
    A check of the stoves "mode" setting might be in order also. After all that, a call or PM to Mike Holton might be in order to troubleshoot it.
  18. Devin86
    Devin86
    Shinnston, WV
    stove is in the main living area house is about 800sq ft poorly insulated at best ran last night on 9-9 and 5-7-1 seemed to do better used about 30lbs of pellets in 9-10 hours cookie was softer but still there. maby lower the feed by one?
  19. imacman
    imacman
    Denver, NC
    Yep, try 4-6-1.
  20. slvrblkk
    slvrblkk
    Northampton, PA
    X2
