Identifing Chains
Discussion in 'Chainsaws and Power Equipment' started by Marshel54, Dec 6, 2017.
  1. Marshel54
    Marshel54
    I have a hook full of chains from saws that I have had for the last 20 years.
    Presently have a 254 and MS250 that I know which chains go to each saw. My Poulan is not running and haven't used it in years.
    In a web sight that I looked at, they showed how to measure the pitch and gauge. They also said to count the drive links.
    If I were to lay the miscellaneous chains out beside the known chains for length, measure pitch, gauge, and count the drive links is it all I would need.
    There may well be some chains on the hook I could re-sharpen and use. They are all from the saws I use to own and same brands that I presently own.
    Throw what doesn't measure up away.
  2. Ikeholt
    Ikeholt
    indiana
    Somebody sells a handy chain sizing guide. Less than 10 bucks I think. I have a couple around, use it quite often. Bailey's or some place like that sells them. Might as well buy a chain spinner while you are at it.
    J. Dirt and Kyle Mulligan like this.
  3. The Wood Wolverine
    Those 3 are the ways to identify, so yes.
  4. J. Dirt
    J. Dirt
    I just got a handful of chains with a recent saw purchase and at first glance could tell that they all didn’t go to the saw! :picard: So I ended up getting out my handy digital caliper and doing it that way. Once I started separating I used a 2x4 with some nails and hung them accordingly labeling each spot with a pencil. In the process of sizing I did some inspecting and out of the bunch ended up throwing out most of them :confused:
    Son had bent and burred drivers, locked up rivers, missing teeth etc.
    BuckthornBonnie likes this.
