How i measure chain cutters. Keeping it equal
Discussion in 'Chainsaws and Power Equipment' started by CoreyB, Sep 14, 2017.
  1. CoreyB
    CoreyB
    South east iowa
    I can not remember which thread I promised to show this in so I will start a new one.
    I have found that needle nose vice grips works best. I have tried micrometers and calipers and a few other methods but this works best for me. Please whatch and share your methods . Also please leave a like and comment on the vid if you would.
  2. TurboDiesel
    Why do they need to be equal?
    Why noy just equally sharp?
    tamarack and p61 western like this.
  3. concretegrazer
    concretegrazer
    Southwest MO
    Efficiency and if they're to far off from side to side it can make a crooked cut. As the cutter is filed away it changes the attack angle from the depth gauge. Thus makeing each cutter bite a different amount if the gauges are all set to the same height like .025. Using a progressive guide to set them makes this problem go away mostly.
  4. Armbru84
    Armbru84
    Sparta, Michigan
    Thanks for sharing Corey. I use a set of mics to measure mine. I sharpen with a grinder now so I only check 2 on each side as I am setting it up.
    clemsonfor and CoreyB like this.
  5. Nixon
    Nixon
    West Sunbury,Pa .
    A quick ,simple way is to hold a left and right cutter back to back . If you can see an obvious difference in length ,make some adjustments .
    clemsonfor, Khntr85 and brenndatomu like this.
  6. Khntr85
    Khntr85
    Indiana
    Yes this is the way I do it, I have never used calipers or anything else....it's super simple and keeps the saw cutting straight!!!
    Nixon, clemsonfor and CoreyB like this.
  7. clemsonfor
    It's not mine but I saw it somewhere on here or another forum? But use a Cresent wrench. Sharpen one side. Set the mouth of the wrench to that size of the cutter and then put it on the other and cut it back to size. I also use a grinder so once set there all going to be the same
    concretegrazer likes this.
  8. clemsonfor
    And yea if there different lengths the saw will try to cut circles. At worse it can actually start binding in cut
    papadave, OldJack and concretegrazer like this.
