How hot can you get your stove?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by IHATEPROPANE, Feb 9, 2014.
  1. IHATEPROPANE
    IHATEPROPANE
    After reading a post in another thread I thought it would be interesting to see how hot we could get our air temps.
    For comparison, and to be as consistent as possible I was thinking we state the cfm of the blower, lbs/hr on high, let it run on high for 1 hour before taking readings, and taking a left, middle, and center reading by either thermocouple or IR. And maybe pellet type. Any other suggestions? I will try to get my results within couple of days.
  2. jdonna
    jdonna
    MN
    Spear Fish South Dakota Pellets.
    Feed 4 out of 5 4 lbs an hour.
    IR left 430 center 610 Right 450.
    No idea on CFM, comparable to the rest I guess.
    IHATEPROPANE and slvrblkk like this.
  3. 343amc
    343amc
    Northeast Lower Michigan
    No fancy temperature measuring equipment here. All I know is mine runs hot enough to keep the house warm on a cold azz day.
    That being said, I'll be interested to see what the various results are.
    will711, gbreda, brokenwing and 2 others like this.
  4. eatonpcat
    More importantly...How hot can you get your wife??
    will711, gbreda, imacman and 6 others like this.
  5. IHATEPROPANE
    IHATEPROPANE
    Nowadays, just above freezing.......
    gbreda, imacman, slvrblkk and 2 others like this.
  6. IHATEPROPANE
    IHATEPROPANE
    Excellent, this is good stuff
  7. mepellet
    mepellet
    Ir is going to give you surface temperature.
    gbreda, DexterDay and subsailor like this.
  8. subsailor
    subsailor
    Winthrop, Maine
    Yup, no way the air temp is 630.
  9. IHATEPROPANE
    IHATEPROPANE
    Yes, IR will only give surface temps...but it is for comparison to others that measure with IR so its still good info.
  10. IHATEPROPANE
    IHATEPROPANE
    JTakeman says he gets 600 degree air
  11. smoke show
    smoke show
    Pittsfield, Wi
    yes, JT has a lot of hot air.
    gbreda, jtakeman, imacman and 5 others like this.
  12. DexterDay
    DexterDay Administrator
    Northeast Oh
    Will have my results tomorrow. Cleaned my Enerzone tonight to have some good exchange heat., ;)
    will711 likes this.
  13. pell it
    pell it
    Rhode Island
    US 5660 cleaned yesterday.
    Cranked on high for an hour this morning burning a Vermont/AWF mix.
    Center - 290 f
    Ends - 275 f
    Measured with this:
    IHATEPROPANE likes this.
  14. imacman
    imacman
    Denver, NC
    Ditto on both points
  15. woodsman23
    woodsman23
    southwestern nys
  16. jtakeman
    Ha ha! Your just lucky its not coming out the other end!
    :p
    brokenwing, slvrblkk and gbreda like this.
  17. IHATEPROPANE
    IHATEPROPANE
    Sooooo.....I didn't have batteries for my IR so I only used the thermocouple. I only had it ob high for 30 min because I started to see some black smoke coming from my vent.....and got a bit nervous :) In hind site I probably should have opened my damper, it almost closed for normal operation.
    Results:
    Left-377
    Center-371
    Right-353
    Attached is a pic of the wood burner magnet at a little over 350
  18. jtakeman
  19. pell it
    pell it
    Rhode Island
  20. slvrblkk
    slvrblkk
    Northampton, PA
    OK...here we go:
    left - 352
    middle - 372 IR gun
    right - 324
    convection blower is a 140 cfm.....currently burning a mix of FSU and AWF's.....
    Wifey started asking what I was doing and started giggling to herself....I told her to shut up...lol
