How do you arrange small loads?
Discussion in 'Modern EPA Stoves and Fireplaces' started by HDRock, Mar 13, 2014.
  1. HDRock
    Spread them out on the bottom, Bunch (stack) them up in the middle of the box
    Or ???
  2. Trilifter7
    Trilifter7
    Waynesville, OH
    I typically put 2 splits east/west then put another piece on top. Sometimes a couple smaller ones on top or one big one, just depends on how fast I want it to burn down.
    HDRock likes this.
  3. HDRock
    I always load N/S, What is better for small loads, N/S or E/W Or does it matter?
  4. Locust Post
    I like burning N/S and I will put 3 in the middle like a pyramid. I've always felt a fire burns better when the flames and air has to come up through cracks and crevises so to speak.
  5. Certified106
    Certified106
    In The Hills
    Coupe of splits N/S and then a couple on top E/W. the two on the bottom are spaced out a bit and then the 2-3 on top are pushed pretty close together.
    HDRock likes this.
  6. Pallet Pete
    Pallet Pete Moderator
    Ovid
    It really depends on your stove. You need to experiment and figure out what gives you more heat and burn time. Small loads in ours are NS and 1/4 to 1/2 a box.
    HDRock likes this.
  7. Trilifter7
    Trilifter7
    Waynesville, OH
    My stove is an E/W stove so I typically load that way. I've had a lot of uglies and odd shaped pieces left over this year from cramming the stove all winter with my best pieces, so I've been adding a couple small splits then some big uglies on top to burn up all the odd stuff I have left from this year
  8. Well Seasoned
    Small load in my particular stove is 2 med splits e/w and 1 more on top same direction.
    HDRock likes this.
  9. HDRock
    I've been doing the same thing,
    With all this really cold weather I have been throwing aside my odd pieces, So I could pack the stove its tight and full as possible, Since it has gotten up into the 20s and 30s I have been trying to use up all this odd stuff ,They are not really uglys, just odd
  10. Well Seasoned
    I try and do the same. Good thinking!
    HDRock likes this.
  11. Trilifter7
    Trilifter7
    Waynesville, OH
    Same here, just a bunch of splits that don't pack well
  12. tuneighty
    tuneighty
    South Central PA
    Depends on the burn I want and the wood that is inside. Some go N/S. Overnight, long burns, on the one side E/W, then N/S over the raked coals on the other side. (The firebox is 30" wide.)
    HDRock likes this.
  13. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    Small load in the 30 is always bunched together. Whether it is n/s or e/w it doesn't much matter for me.
    With the VC stoves, the firebox is shallow and the load is always e/w and bunched together.
    HDRock likes this.
  14. papadave
    I have 2 small splits n/s, with 2 more e/w on top, log house style going right now...Maple.
    With more coals, I've been doing more e/w loads, with one in back, another on the coals I pull forward and the last one on top sort of diagonal.
    Chvymn99 and HDRock like this.
  15. thewoodlands
    thewoodlands
    We burn N/S, a small load of firewood for us is about five splits. three on the bottom and two on top.
    I think your E/W burning will give you a longer burn. Our Liberty will take 24 inch splits E/W, I have a good size Basswood down in an area we need the trail to go so I'm thinking about cutting it 24 inches long so we can use it for the shoulder season.
    HDRock, papadave and jeff_t like this.
  16. jeff_t
    jeff_t
    SE MI
    THIS is a shoulder season load.
    Silly non-cat boys. It's Blaze King weather today [​IMG]
  17. fox9988
    fox9988
    NW Arkansas 72717
    For me, the difference in a small load and a full load is usually only one split:emb:
  18. bogydave
    I load almost full but not as particular to place each
    split to get as much as I can & I don't stack it tight
    To the top
    Full loads seem to burn better
    N/S
    SolarandWood, HDRock and jeff_t like this.
  19. jeff_t
    jeff_t
    SE MI
    I'm pretty sure at least one of those splits above is 1.5 cu ft. Another is darn close [​IMG]
    Chvymn99, fox9988 and HDRock like this.
  20. Chvymn99
    I do it like Papadave, I can usually get 3 layers in, (N/S then E/W then N/S).
    HDRock likes this.
