Hitch advice
Discussion in 'Chainsaws and Power Equipment' started by DaveGunter, Jul 29, 2016.
  1. DaveGunter
    DaveGunter
    I need to buy a ball mount for my truck hitch. I've never towed anything with a pickup before, always with an SUV. Wondering about tow height. Are the adjustable height ball mounts needed? The center of the receiver is 16" off the ground. Will a straight ball mount work OK for most trailers? The adjustable heights seem to be either a couple hundred $, or several hundred $, a little worried about slop in the adjustable height ones. I don't do a lot of towing and certainly nothing too heavy, not more than 5k.
  2. lukem
    Depends entirely on the trailer you're going to be towing, but a 2" drop is common for full size trucks pulling most trailers. You can always flip it over for a bigger trailer if you need the extra lift.
  3. bassJAM
    bassJAM
    Cincinnati, OH
    If you always tow the same trailer, I'd just find a ball mount with the appropriate drop you need. Like lukem said, 2" is common. No need to spend several hundred when a simple $40 mount from Walmart will do the job.
    clemsonfor, cgraham1 and cnice_37 like this.
  4. cnice_37
    cnice_37
    I'll second the above, if it's one trailer get the cheap solution. Just measure what you need. On the old Ford I had a 2" drop. On the Subie I flip over a 1" (?) drop to get a 1" rise.
    Hitches often come up on CL here, might surf there if you really want the fancy kind.
  5. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    Single or dual axle trailer? If single it really does not matter (as long as you can keep your load on board). If dual axle, you need the appropriate hitch height so it rides level and both axles are equally carrying the load.
    clemsonfor likes this.
  6. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    I would eyeball the trailer you are going to haul to level or to an upward angle, figuring it will level a bit with a load and squat of the truck when loaded. Then back up to it and measure the drop/or rise needed. You always want the load to be heaviest just in front of, or directly over the axle but not all on the tounge, and as level as possible to elimante trailer sway!
  7. DaveGunter
    DaveGunter
  8. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Just make sure u-haul doesn't have something funky like a 2-1/8" ball .
    Gary
  9. eatonpcat
  10. thewoodlands
    thewoodlands
    Make sure you get the interlock ball mount and the interlock ball.
  11. MasterMech
    U-haul usually has ball mounts for sale and I bet they could match up the truck and trailer right there on the spot.
  12. Boomstick
    Boomstick Banned
    Saratoga county ny
    Depends on the pickup you are using, when I used u huals dumpy 5x8 wich isn't really 5x8, it measures from the outside of the fender measurement. My trailblazer did fine with its height or lack thereof. Used the same receiver I use for the sled trailer and dual axle car trailer.
    I wouldn't count on them having anything or knowing what will work. Some stores are better than others. All they know is tow ratings.
  13. HDRock
  14. clemsonfor
    Depends. Some trailers are smaller than others. If there small on 13" tires or 15" tires?
    Also depends on your truck and the actual hitch and how much it drops or tucks in. Some of the larger trucks need 3" or more.
    Harbor freight has some adjustable ones I think. I am going to get the weight distribution hitch and it is adjustable up and down, and I think it's only around $100
  15. Boomstick
    Boomstick Banned
    Saratoga county ny
    Yeah thought about their weight distributing hitch, it's 200 made by haulamster. I've always eyeballed it just never tried it.
    It's rated for 10k. If I already pull 10k and it makes it handle that much better it will make me want to pull even more?
  16. clemsonfor
    Well it may. But your truck only has so much power and the trasmission is only so strong. Just think of three or 4 thousand dollar transmission . That would be enough for me not to max it even more.
    I want to buy that hitch to lift up the back of my sequoia when I haul a full trailer.
  17. MasterMech
    Bag it! :banana:
    concretegrazer likes this.
  18. Boomstick
    Boomstick Banned
    Saratoga county ny
    I build my own transmissions after dealing with " transmission builders" I read up and actually have them not only lasting but take a punding.
    It's not a power( cars and trucks have more than work trucks in the 60s 70s 80s or 90s) or durability thing as it is control. Stopping Turning. That's the point of a weight distributing hitch.
    For example pulling a TLB on the interstate to do 70+ to keep up and not hinder traffic it sways at speeds over 70. And I can't move the load on the trailer over the axles because of its length.(to keep it from swaying)
    That's more to the point of the op, to have the trailer ride correctly.
  19. TurboDiesel
    You'll want the trailer as close to level as possible. An inch high or an inch low won't make too much difference.
    You want to be sure to have 10% of the trailer weight on the tongue. This is probably the most important part of towing.
  20. MasterMech
    And there are always trade-offs no matter which solution you use. Bags will not help with sway for trailers that have large side profiles or poorly distributed loads. And all the extra tackle that comes with dual cam sway control WD setups is a liability off-road and can get in the way of tight maneuvers in reverse.
