Advice needed please, having a issue after start up. Auger will feed and ignite and goes out. Hit reset and would run fine about a week ago. Stove and vent system are clean. I have checked the door gasket. Jumped out the vacuum switch, hopper lid switch. Cleaned auger tube. Did a continuity check on the snap disks. Call light stays on red, thermostat seems ok. I have not bench tested the auger but it seems to be good on start up, might I have a bad control board ?, also have installed a new thermocouple which was after market. Unit is going into yr 5 of service. Thanks
Just based on what you said, sounds like it's not seeing fire (temp) after start-up. Is that what the thermocouple is supposed to do? Was the unit unplugged all summer?
On the thermocouple, you'll need to check for millivolts once its unhooked and you apply heat to it. Have you reseated the control board yet? I have a spare board on hand that I'd gladly send you to try out before you go buying a new one.
I'm assuming the LED within the control module is not turning green and then red when thermocouple reaches it the millivolts needed for steady operation. Check to see if thermocouple is fully seated in ceramic cover. I've seen bad new thermocouples before, even seen one with reversed polarity (put out good millivolts but not right polarity, assume connectors were installed incorrectly) so stove would never run beyond initial pellet feed.
Thanks to both for advice, yes I have reset the board and will do the same and flame out. Board will stay red , no yellow or amber for thermo issue. I am waiting for a oem thermocouple to arrive that I found a deal on. Vender said they have had a run of bad aftermarket ones like I purchased. I have rechecked the ceramic cover and all connections. Slvrblkk thanks for the offer.
Yes...I know there was a bad run on the aftermarket thermos, hopefully you get the replacement and you're good to go.
Green light on, fire in the hole folks. Installed a oem thermal after work. Defective aftermarket thermal. Jeez after 25 yrs in the HVAC field ya think I should have know better. Ah well life is good again. I guess oem parts is the way to go on these little pigs. Maybe just my chit luck. Snow in the Mts. tomorrow night. Wait a minute I am in the Mts.... Sometimes us ole farts aren't so smart.....
Good deal!!! Glad it worked out! I've used both oem and aftermarket....I must have lucked out as I haven't run into any issues yet ***fingers crossed***
