Has anyone found a technique to dry Oak in a year ?
Discussion in 'The Wood Pile' started by Rich L, Apr 19, 2022.
  1. Rich L
    Rich L
    Eastern Mass.
    I'm looking for a way to dry oak in a year.Anyone know of a way to do it ?
  2. Theashhole
    Theashhole
    Osceola, In
    Kiln or an oven
    Sent from my LE2127 using Tapatalk
    Rich L, T.Jeff Veal, Chvymn99 and 2 others like this.
  3. ole
    ole
    Rock County Wisconsin
    split it small real small
  4. buzz-saw
    buzz-saw
    Ct.
    Split into toothpicks and lay them out single layer in the driveway? For the summer.
    Honestly not sure if it would be doable without some sort of kiln.
    I just take it knowing it is not going to get burned for a while.
  5. brenndatomu
    Hillbilly solar kiln.
  6. Redneckchevy
    Redneckchevy
    Ladysmith, Wi
    Nice hot fire drys them in a day, that's about the only way I know :rofl: :lol:
  7. The Wood Wolverine
    I agree with a DIY kiln of some type. Split small, cover in black wrap w/ a fan to pull air through and place it in full sun.
  8. Chud
    Chud
    NC
    Stack It in Death Valley?
    Rich L, Chazsbetterhalf, JDU and 6 others like this.
  9. brenndatomu
    Hmm...I like it...I think I'd wrap it up tight for max heat in the daytime, then open up and turn on a box fan to push the condensation out over night. (at least the first few weeks/month when there is a lot of moisture to get rid of)
  10. Geoff C
    Geoff C
    NEPA
    I’ve heard the shelterlogic firewood seasoning sheds work pretty well.
    I don’t know if they are discontinuing them they are in sale on their website
  11. buZZsaw BRAD
    I feel your pain. My main reason for not liking oak. Split it small and give it full sun helps. May not be under 20%. I see so many sellers trying to pass off oak as seasoned. Fresh split from 1-2 year old logs.
  12. Eric Wanderweg
    Split it into thin board-like splits, top covered, good airflow and as much sun as possible. According to some, it takes a year per inch to dry, so technically a 2” thick board without bark could reach that threshold….
    Or…. Try what I did here. This was less than a year CSS’d and it dried to under 20% no problem.
    Sub-Optimal Oak Experiment
  13. Chris F
    Chris F
    Micksburg, Ontario
    I cut my oak in Sept. then the following August it's put in the basement and the dehumidifier goes on and by burning time it's pretty darn good. I have the hose from the dehumidifier going into the sump hole and when I first start it there's a drip every second. By the second week that's gone down considerably. I also split them a bit smaller because of the fact oak is slow to dry.
    Works for me.
  14. Lastmohecken
    Lastmohecken
    Arkansas
    This is what I did for many years. My nephews would cut me a few ricks of standing dead Red Oak every late summer or early fall. I would stack it on the porch, and burn it the same year. This is before I became more educated as to what seasoned wood really was. I don't know what the moisture content was, but it burned good enough. I was using a Pacific Energy Super 27 stove and I burnt hot fires. I did this for literally 20 years, and I had no build up in my flue. Granted some of the wood was carried over to the following year, at times. So, some of it was seasoned at least a year.
    Now, that I am retired, I cut all of my own wood and I am on a 3 to 4 year rotation now. So I will be burning more seasoned wood from now on, and it is better. But standing dead Red was my go to wood for many years. All I am saying is; if it's standing and dead, it's doable but I think my secret was to burn a hot fire, at least once daily.
    But green oak, No!
  15. Creekin
    Creekin
    Manitoba
    3 years ago in spring I had nothing but semi green oak and ash that was slated to burn that following winter
    I built a makeshift solar kiln with just cheap poly and pallets, dehumidifier, and an old furnace fan
    During the day, it would get about 120° on a sunny day,kept the fan going on low with a vent that funneled moist air at the top
    At night I turned on the dehumidifier, typically got about 1 5 gal pail per night
    This was about 6 cords total
    Fast forward to fall and the ash was good to go, but oak was not quite there, thankfully it wasn't a super cold winter and was able to hold off on the oak till the following winter
    Supplemented the ash with lumber cutoffs from a pallet making business close by
    Never measured moisture content of anything, so not a very scientific experiment
    Would i do it again? Probably if I had too, but not the most ideal
    Second year the oak was good to go, pretty much lit with a match
    This wood was all for an owb, split a bit on the larger side
  16. jo191145
    jo191145
    Ct
    Makes a difference if it’s dead oak or fresh cut living tree IMO. Dead oak the sugars in the sap have broken down and you’re dealing with mostly water. Fresh cut you’re drying sap. It’s a little harder to dry sap.
    Either way it’s still not easy. The smaller you split the more area exposed to dry, less area hidden deep unexposed.
    MikeInMa, Rich L, Theashhole and 5 others like this.
  17. Chvymn99
  18. Rickyblazin
    Rickyblazin
    Pottstown PA
    Once i got a bunch of oak from a huge trunk that was still alive…it took 3-4 years to dry out in splits…the way to burn oak is bury it behind other wood like ash and poplar and forget about it
  19. T.Jeff Veal
    Move to the desert or way down south, stack in a metal shipping container and add a couple fans with vents on other end...
  20. yooperdave
    :rofl: :lol::rofl: :lol::rofl: :lol: :whistle: :zip:
