Garage Door Opener Question
Discussion in 'The DIY Room' started by lukem, Jan 15, 2020.
  1. lukem
    I have a 5 year old garage door opener with two remote controls. I have replaced the batteries in both. Both remotes will open the door from down the street.
    Neither one will close the door unless you hold the remote out of the car window, 10 feet away from the door. Very frustrating.
    Any ideas other than set it on fire and buy a new one?
    Chvymn99 and Jack Straw like this.
  2. Canadian border VT
    Cotton swab with a little rubbing alcohol on both remotes and receiver eye. Dust dirt etc clogs them..
    Timberdog, Chvymn99 and Jack Straw like this.
  3. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Just need to top them off with some reverse juice?:rofl: :lol:
    Gary
    If the opener has a wire hanging down for the antenna maybe try putting that in a different position?
  4. lukem
    Tried that.
  5. lukem
    This isn't an IR setup....no eyes.
  6. Gary_602z
    Gary_602z
    More than likely it is made by Chamberlin? If so they have really good customer service! I have had to call them a couple of times!:whistle:
    Gary
  7. Gary_602z
    Gary_602z
    Looks like a CFL or Led light can cause problems also.
    Gary
  8. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    This definitely affects my liftmaster. When I put an LED bulb in the opener itself.
    But not the chamberlain in the next bay
    brenndatomu, Chvymn99 and Jack Straw like this.
  9. yooperdave
    So it's you doing that, huh lukem ? My dang doors have been opening and closing unexpectedly at the most unusual times! Knock it off, please!
    Noticed the same thing here with one opener. I can be 2 blocks away and the door will open with the remote. But, try closing it and you have to be in the immediate area.
  10. lukem
    I'll have to give that a try. Not sure if I have any non-LED bulbs around here anymore.
  11. lukem
    Further reading suggests that there low interference LED bulbs out there. I'm going to give them a shot.
  12. billb3
    Just unscrew the light bulb to test.
  13. lukem
    New bulbs fixed it right up. :yes:
  14. yooperdave
    Still having troubles with the remote closing command?
    At one point within the last couple of years, the door stopped closing. One of the electric eyes was ever so slightly out of alignment.
    But not related to remote issue like yours.
    brenndatomu and Chvymn99 like this.
  15. lukem
    Everything works great now. Can open and close the door from the road easily.
  16. Easy Livin' 3000
    Easy Livin' 3000
    North side of the ridge
    This was a success! Where do you find low interference bulbs?
    brenndatomu likes this.
  17. lukem
    I bought mine on ebay.
    Easy Livin' 3000 and brenndatomu like this.
  18. brenndatomu
    Or just stick with incandescent bulbs...they aren't on enough to use much power...but I suppose once those are no longer made one will need to know about low interference LED bulbs...
    yooperdave likes this.
  19. lukem
    They are on a lot in my garage for extra light in the winter, and the door is open a lot in the summer with kids and dogs constantly tripping the sensors that turns on the lights. The LEDs are worth the spend.
