Fuel funnel with built-in filter
Discussion in 'Chainsaws and Power Equipment' started by Russell, Feb 9, 2016.
  1. Russell
    Russell
    South Coast , Massachusetts
    I recently had a bad fuel problem even though I use stabilizer and try to keep my container's clean . In case you guys didn't already know about this product I thought I would share . And if you have one how do you like it ?
  2. bushpilot
    bushpilot
    Eastern Washington
    We used a Mr. Funnel for fueling aircraft from jerry cans at village airstrips in Africa. (They used to have a sticker on them saying "not for aircraft use" ... But they worked great.) They separate water out well, as long as there is no alcohol in the fuel.
    I really like them.
    clemsonfor, Barcroftb and Russell like this.
  3. XXL
    XXL
    Ontario, Canada
    I like that.:yes:
    clemsonfor and Russell like this.
  4. Oldman47
    Oldman47
    Illinois
    So, how do they work with a 50:1 mix? Do they change the mix proportions by stripping the oil?
  5. Russell
    Russell
    Q. Will the filter work on mixed fuel with 2-cycle oil in it?
    A. Yes, but if your 2-cycle oil has a detergent base the detergents can break down molecules of water and some water might pass the screen. Usually only a drop or two but if you are concerned, filter the fuel a second time because unless the sump is full of water, it is not possible that any water passed the filter.
    Barcroftb likes this.
