flue liner question
Discussion in 'Modern EPA Stoves and Fireplaces' started by JoshuaE, Oct 16, 2020.
Tags:
  1. JoshuaE
    JoshuaE
    So I bought a wood insert for my upstairs fireplace. I am about to purchase a flexible liner kit. I am curious about if its necessary to wrap the liner with insulation? It is centrally located in the house. I have come across different views on this. Most only doing it for exterior chimneys. All my chimneys run through the center of my house parallel to each other (3 in total) I plan on burning the wood furnace and the new insert mainly. My house is large so I needed the insert to help with take the edge off during colder temperatures or when we need just a little heat so it will be used often. Thanks for any input.
    brenndatomu and ReelFaster like this.
  2. blujacket
    blujacket
    Kettering, OH
    I’d insulate it. Warmer flue, less creosote buildup.
  3. moresnow
    moresnow
    Agreed. Not to mention most existing chimney's don't have the required clearance to combustible's to allow a non insulated liner install. Having a professional sweep thoroughly inspect and properly clean the chimney prior to lining is regarded as the correct procedure. Good luck, be safe. Welcome to FHC.
  4. brenndatomu
    This ^ ^ ^
    Insulate for best performance and safety...don't play around with the fire you are bringing into your house...peace of mind is worth alot!
    Slocum, moresnow and Rush Battle like this.
  5. Semipro
    Semipro
    SW Virginia
    You've gotten good advice above.
    Also, consider that since this is an upstairs installation, your flue length will be shorter so the draft won't be as strong as a lower floor installation.
    The flue is the "thermal engine' that powers the stove.
    Insulating will increase the liner temp and will increase the draft ensuring good stove performance and decreasing the chance of smoke blowback.
  6. brenndatomu
    Oh, and make sure you don't waste your money on a 2 ply liner...more money for an inferior product!
    Rush Battle likes this.
  7. ReelFaster
    ReelFaster
    S.Jersey
    brenndatomu and Rush Battle like this.
  8. ReelFaster
    ReelFaster
    S.Jersey
    BTW Welcome to FHC :handshake:
    brenndatomu likes this.
  9. Locust Post
    I will reinforce this statement from experience.
    Rockford Chimney online, great company
    yes absolutely insulate !!!!
  10. Locust Post
    Another note, what they call the smooth wall liner is the 2 ply liner.
