Hi all, My brother has a 25-pdv and he went to change the glass gasket and the screws easily snapped flush with the door. I'm going there in a few days to extract them. Does anyone know the specs for those screws, or if i have to drill and tap, what grade screw should I buy? Thanks in advance, Joe
Don't know offhand what they would be, but a call to Tech support probably can get you that info, if not the actual screws themselves. They do make a "Glass Support Set" that just has the metal plates that hold the glass & gasket in......maybe you could use that as a starting point (AC-GS19). Tech Support is (800) 245-6489
update - nothing got the screws out of the holes. soaked in "go juice" for days, drilling the middle then easy outs didnt work. Even tried heating things up a bit. finally gave up and drilled a slightly larger hole straight through and used 2 stainless bolts and nuts with some sealant. not the most pretty but i painted them with stove paint and barely notice them. more importantly it worked.
