★★☆☆☆ Easy Heat Wood Pellets (Review)
Discussion in 'Pellet Fuels' started by slvrblkk, Mar 22, 2015.
Thread Status:
Not open for further replies.
  1. slvrblkk
    slvrblkk
    Northampton, PA
    Easy Heat Wood Pellets results: FINAL RESULTS
    Temp Average – 220-330 (new thermocouple on door, cannot compare with previous older reviews)
    Ash Volume – 20 ounces
    Ash Weight – 2.50 ounces
    Ash Percentage - .41%
    Fines In Bag – about 1 cup
    Pellet Length Avg. – 1/8” – 1.5”
    Bag Weight – 40.6 lbs. (2.28 lbs. left in hopper)
    Burn time – 24 hours (approx.)
    NOTES:
    Donated by Will
    I believe these were in the $250 range?
    Lots of fines in the bag
    This was just the second time I cut a test short so I’ll just start with the good. These smell great, like fresh cut plywood, but that’s where it ends. Pellets ranged from bits and pieces up to 1.5”. The pellets are not very dense as I didn't have much room left in the hopper after filling it. Definitely seems like all softwood. The pellets hang on to each other and do not slide well so I had a major issue with the pellets funneling in the hopper. Ash was a very fine light grey. Ash volume was more than I had expected based off of last year’s test. These produced a dirty burn for me and the glass had a nasty brown film on it.
    All in all I couldn't squeeze good heat out of these even at a high feed rate. When your sister company manufactures pallets and wooden crates and such you have to wonder if the scraps are turned into pellets. It’s bad when equine bedding pellets tops these by a mile. These are 2 stars (and that might be generous)
    Disclaimer: As with everything....YOUR MILEAGE MAY VARY....the review is just my opinion of them
    IMAG0638.jpg IMAG0639.jpg IMAG0628.jpg IMAG0630.jpg IMAG0640.jpg IMAG0641.jpg IMAG0637.jpg
Thread Status:
