Do I need Another Stihl 660????
Discussion in 'Chainsaws and Power Equipment' started by Dakota Hoarder, Oct 21, 2019.
  1. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Do I need another 660? Of course not!!!
    But you know the story! I got my eye on one for $650. Owner has receipts of recent rebuild by a very reputable shop in the state. Looks like they checked everything and fixed what was needed (including piston) with all OEM parts. Cosmetics look good. Comes with 25” BC.?
    Is there anything else that should be of any concerns after a good rebuild?
  2. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Here’s the pics of the 660 year m looking at.
    1CB5A0AE-A5E3-423E-B5B4-DE677F87960F.png AA7BA043-5EA6-4D72-8BE2-132A72967AE3.png 5B5B785A-CE4B-4296-AFBA-43D6DD3A3C4D.png
  3. jtstromsburg
    jtstromsburg
    Stromsburg, Nebraska
    FIFY. Sounds like you’re just wanting encouragement, but surely won’t find anybody encouraging a saw purchase here...
    Got it home yet?
    How bout Now?
    Gonna need a video of it running.
    Woodsnwoods, M2theB, MFMc. and 5 others like this.
  4. bogydave
    Of course you don’t need another one, but
    What’s that got to do with it .?
    “Want “ outweighs “need”. ..... always :D
    Woodsnwoods and Dakota Hoarder like this.
  5. tamarack
    tamarack
    paulina oregon
    Buy it. If nothing else a clean, good running Stihl 660 seems to hold a good resale value.
  6. Stlshrk
    Stlshrk
    Central Virginia
    If nothing else you could flip it and not lose $$.
    :saw:
  7. stuckinthemuck
    stuckinthemuck
  8. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    After a good rebuild? Naa... run it a touch rich and listen closely to the tune.
    After a questionable rebuild? Lots...
    It’s hard for me to trust rebuilt saws by probably 95% of the population who can fix them. The 5% are mostly on here or AS. To be honest, I struggle trusting two-smoke “mechanics” since I know all too well what should go into a rebuild.
    Cutting corners, working fast, dirty work conditions, aftermarket parts not disclosed, are all recipes for disaster on two-strokes. They have less margin for error compared to some other engines (debatable, I know- but how many mower shops avoid engine work completely and just clean carbs and sharpen blades all day?).
    *wiggle the crank if the owner lets you
  9. Horkn
    Don't come here asking if you need another one. We're not going to convince you not to get it.:rofl: :lol:
    So, is it in your possession yet?:whistle::handshake:
  10. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Thanks for the info! I’m very confident in the shop that did the work. Probably the most reputable Stihl dealer in eastern SD. I’m sure they went through it well.
    I’m wondering more how well the bottom end will hold up over time or if bearings, cranks ect will eventually have to be replaced?
    Woodsnwoods, Horkn and Chvymn99 like this.
  11. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Going to check it out this weekend, it’s about an hour away. Not sure if I’ll pull the trigger since I don’t need it, but like said, I’m sure I could get my money out of it if I sold it.
    Woodsnwoods and Horkn like this.
  12. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    The bottom end question depends on a ton of factors. “Hours” just being one.
    I will say that 1122 series saws are usually used hard by pros or on mills. They run big bars that can, in theory, put more stress on the pto bearing and crank (chain contractions, ability to pull a dull a chain, etc).
    I’ve rebuilt two with pto bearing issues. I’ve been into a few other carcasses where bearings were obviously shot.
    Any shop worth its salt will carefully examine a crank and bearings before fitting a new top end.
    Woodsnwoods, Horkn and Dakota Hoarder like this.
  13. ironpony
    ironpony
    Mid Ohio
    Yes you do need it.
    What if you go into the woods and your saw dies or gets bound in a tree?
    You HAVE to have another saw of equal or greater size to get it out.
    A 660 for 650 you are saving 10 something or other.
    Why wait till the weekend go directly after work and you could be back for dinner.
  14. MFMc.
    MFMc.
    Idaho
    I look at it this way: Since there are just so darn many trees over 6 inch in diameter, every hoarder must eventually have an 880 M (or a pair), $2k out the door. How is saving $1350 not the responsible thing to do, when we all have families to provide for? We can’t always think about ourselves, you know.
  15. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    So the plot thickens on the 660. Through Texting back and forth trying to figure out if we can set up a meeting time he mentions that he has a newer, 2013 660 that has not been rebuilt. So now do I try to just buy one saw or both. If I buy both I’m definitely selling one. Problem is it’s not like used 660’s are flying off the shelf! I’m sure I could get a little better deal buying both.
    Says he he’s selling to get a 462... makes sense.
  16. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I bought a second MS880 for no reason....so I say go for it.....
