Critique my tune
Discussion in 'Chainsaws and Power Equipment' started by rotorburn, Sep 24, 2022.
  1. rotorburn
    rotorburn
    Jersistan
    On my roughly 30 hour 372 xp, I noticed the engine screaming more and less willing to four stroke. Also, the idle would surge and a pull on the trigger would cause bogging if I didn’t nurse it up with a few taps.
    I gave the L screw an eighth turn CCW which smoothed out the idle and improved throttle response. Hooked up the tach and got the idle to 2700. Gave the H screw the same eighth turn CCW and it maxes out at 12800 and blubbers a little when I lift it out of a cut. Does this sound like a good safe tune or should I screw in the H to get closer to the rated max rpm of 13600?
    M2theB, Screwloose and Chud like this.
  2. Chud
    Chud
    NC
    It doesn’t hurt to be a tad rich on H. How does it feel pinned in the cut.
  3. The Wood Wolverine
    What I'd recommend, make a bunch of longer cuts and get that saw nice and hot, then make sure you have a good 4-stroke burble when you rev it unloaded. I personally don't rely on a tach. I do have one just to see what the saw is turning but I don't tune w/ it.
    Duane(Pa), Nixon, huskihl and 4 others like this.
  4. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    So if you can’t get the burble at WOT without a load, is it too rich or too lean?
  5. Screwloose
    Screwloose
    Typically lean.
  6. rotorburn
    rotorburn
    Jersistan
    It feels more like it did right out of the box. Revs up quick and settles in to a nice happy zone where it’s cutting with torque rather than horsepower. Before the adjustment, it had more of a peaky, sport bike character. When the chain was less than perfectly sharp, I was catching myself cutting at part throttle to avoid overrevving.
  7. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Numbers seem good. Replace the fuel filter and clean the air filter… then check again after it’s been hot like said above.
  8. The Wood Wolverine
    If you can't get 4stroke, it's lean.
    Here's a vid (not mine) w/ decent sound quality.
    rotorburn and Sandhillbilly like this.
  9. rotorburn
    rotorburn
    Jersistan
    That was an excellent use of 4 minutes. I’ve read a bunch of tuning guides but nothing explains it this consicely. Love me some YouTube!
  10. Sandhillbilly
    Sandhillbilly
    That’s a good video and sound. Me thinks I gots a little tuning to do
