I'm trying to add heat to my shop I got 1" thermopex burried I'm ready to get a pump I have a central boiler 6048 IV always used taco 007 pumps for my other runs. This time my shop is uphill from my stove it's 400ft apart with about 30ft of lift. What pump would be best? The tech support at central boiler said to stack two 009 pumps together but I can't find anything online about stacking pumps together. Yes I know it's a long run and I'm going to use more wood... Any info on what pump/pumps I should go with would be greatly appreciated
I have the same stove as you & have heard of putting 009s at the building & stove together. I also understand taco came out with a new pump specifically for OWBs & longer runs it is a Taco 2400-20WB-3P A great source for information on what your trying to do is a company in CT called Alternative Heating & Supplies they are extremely helpful give them a call. The fellow I spoke with was Eric & he was very knowledgeable. They’re phone number is 203-881-1602
I just noticed your from PA as well. What part? I’m in Northeast Pennsylvania. Not to far from the Poconos & Scranton.
Glad they were able to help you. Let us know how it works out. I would be particularly interested to see how much your wood consumption increases. We burn a lot of wood in our 6048 but we are heating a lot. Thanks.
Got taco 2400 20wb pump installed and fired up stove yesterday, took some work to get the air out of the lines but everything seems to be working great! Altogether the total loop is approximately 950 feet 35ft uphill running through two radiators for forced hot air In two sections of my shop it's 1" line, still to early to tell on wood consumption but doesn't seem any worst that when the stove was only 20ft from shop
Ya keep us informed. I need to really dig into the why of my system not making enough heat for my place
Everything is working great I'm only feeding stove once a day so far. When we got the snow the other day it didn't melt the ground where my boiler lines are. The underground line I used was 8$ a foot and I believe it's as good as themopex from what I can tell. Just need to get some more wood cut now!
