Chopping block pics. Lets see 'em
Discussion in 'The Wood Pile' started by buZZsaw BRAD, Feb 10, 2020.
  1. buZZsaw BRAD
    A sugar maple stump cut off i scrounged Summer of 2018. Drove an hour and a half across Connecticut with a PU full of wood including this! Still cant believe i got it on my truck in one piece by myself!
    Dont use it as often as i should and noodle on it more than anything.
  2. MikeInMa
    I have some crotch pieces that I've cut flat on both ends.
    I have a few around the wood yard. I try to split near where I'm stacking.
  3. buZZsaw BRAD
    I do the same for the most part. I had intended to slice a cookie or two from it, but never did.
  4. sirbuildalot
    sirbuildalot
    Mass
    If I hand split I typically leave what I’m splitting on the ground.
  5. Woodsman
    Woodsman
    NW CT
    Nice block Buzzsaw. I’ve got a big fat hemlock round that’s been through a few hand splitting sessions. Will see some action soon when I split some ash to fill in the wood stack at the sugar house.
  6. billb3
    I was using a pine stump for a while, but the last time I used it a round went thru it. Full of termites.
    The only thing I have right now is the bottom round of a spruce tree that is far too heavy to pick up. Still working on splittting the last of the spruce rounds I have.
    I split some pine by hand, but they pop easy and I've doing those on the ground as they don't have to be whacked very hard and the one or two that the maul gets stuck in just gets persuaded to finish on a granite rock nearby.
    Splittin by hand isn't good for my back but I've been doing a little lately because, feeling good. Plus, dragging the splitter out for a few minutes of daylight really isn't worth it and I'm not leaving it out with a tarp over it. It'll never get put away if I start that routine.
  7. lumberjohn
    lumberjohn
    Ky
    4D5EA6EC-5931-44F9-B2C7-1CC740C3771F.jpeg One more try.
    Long time reader, first time poster
  8. buZZsaw BRAD
    Welcome to the FHC lumberjohn :handshake: Great to have you on board. Glad you finally decided to join us! Lots of knowledge, good and bad humor here. I fall into all three of those catagories...sometimes more than the other!
    Ive never tried the tire method in 40 years of hand splitting. My landlord has a huge stack of them and ill hafta scrounge one and give it a try.
    Nice looking pile of wood BTW!
  9. Dan-VA
    Dan-VA
    Chesapeake, Va
    Here's where I do all my splitting, everything by hand right now, hoping to buy a gas splitter within the next year [​IMG]
    Sent from my SM-G975U using Tapatalk
  10. lumberjohn
    lumberjohn
    Ky
    Brad I’ve always used rear 4wheeler tires, that’s my third or fourth. I hadn't cut the sidewall out yet at that time.
    It has really been a relief to my back not having to bend over after every swing. Added a Fiskars hookaroon last year which was another huge relief.
  11. Mag Craft
    Mag Craft
    South East Wyoming
    Ok
    This one is for splitting.
    This one is for noodling.
    These two are for milling.
    eatonpcat, Thor, Winston and 14 others like this.
  12. Chaz
    Chaz
    Southwestern NY
  13. Mag Craft
    Mag Craft
    South East Wyoming
    Looking good LumberJohn. Welcome.
  14. buZZsaw BRAD
  15. Mag Craft
    Mag Craft
    South East Wyoming
    Yes I welded the handle on. It was just a cheap wedge and some scrap pipe and then wrapped it with pipe insulation and duct tape. Works good.
  16. Backwoods Savage
    Although I use hydraulics now I did split wood probably for more years than most on this forum have split wood. I admit that I did try a splitting block and hated it. Therefore I did all the splitting on Mother Earth. It did not matter to me if the ground was frozen or not; I'd just split the wood and I believe it saved time not having to mess with a splitting block.
  17. Backwoods Savage
    Welcome to the forum John.
  18. tamarack
    tamarack
    paulina oregon
    I got 2. One inside the woodshed, and one outside. IMG_20200211_080517833.jpg
    eatonpcat, Thor, Winston and 6 others like this.
  19. tamarack
    tamarack
    paulina oregon
  20. buZZsaw BRAD
    I seldom use it anymore and mostly split on the ground as well. I was working in my main PA that day and thought it'd be cool to post pics and see what everyone else does. This one is only a foot high which helps when i do use it!
