Best sled for moving firewood from point A to point B?
Discussion in 'The Wood Pile' started by Farmchuck, Dec 5, 2019.
  1. Farmchuck
    Farmchuck
    Nepa
    Okay boys & girls what’s everyone’s best recommendations for a person powered sled for transporting firewood in the snow?
  2. amateur cutter
    Biggest heavy duty plastic toboggan style you can find. Rope has one that I can't remember the brand. They use them behind snow machines.
  3. billb3
    For a person powered sled the cheapest thing I've ever used that was practical was a round sled, but it was an aluminum one. Unless they make one the same size in plastic most I've seen are too small.
    If you had a bunch of plastic barrels around it probably wouldn't be hard to make something out of one of those that wouldn't need power to pull it.
  4. Scotty Overkill
  5. Scotty Overkill
    I've wanted to build an old school runner Sled for firewood/maple syrup season for many years, just haven't found the time to do it. Raised runner sleds are much easier to glide through deep snow with a heavy load.
  6. Horkn
    That's pretty much like mine, except it's a different brand. It works great. I keep the gorilla cart on the patio for when there's little to no snow, and the sled on top of it. The sled works great as a cover to keep the wood in the cart dry.
    I've found that if there's even a half inch of snow, that the loaded sled is easier to get up from the stacks to the patio than a loaded gorilla cart, due to the small hills we have. Both the gorilla cart and the sled hold the same amount of wood. I'll even transfer the sheds content to the cart in the deck, then cover that cart with the sled.
  7. ReelFaster
    ReelFaster
    S.Jersey
  8. sirbuildalot
    sirbuildalot
    Mass
    Any polyethylene sled like those used for ice fishing should work. Otter is a well known one that was previously mentioned.
  9. unclefess
    unclefess Guest
    jet sled ,any sporting goods store should have them or a similar model ,works great we have used them for years for hauling deer ,wood ,ice fishing and trapping equip.
  10. cnice_37
    cnice_37
  11. Stinny
  12. Ejp1234
    Ejp1234
    MD
    I use jet sled on deer, good stuff
  13. Warner
    Warner
    050A8313-F324-4620-9456-B3970C4D4907.png The magnum is pretty large. You would need a fairly heavy machine to pull it fully loaded.
  14. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    The hood from a 1970’ Chrysler that’s about 12’ long! :rofl: :lol:
  15. Mag Craft
    Mag Craft
    South East Wyoming
    Got my vote.
  16. amateur cutter
    Yep, good coat of wax & they slide nice. Have that nice "keel" down the center to keep em going straight too.
  17. Farmchuck
    Farmchuck
    Nepa
    Thanks for all the input folks. Lots of great ideas. Now I’m not sure whether to hit the BBC sporting goods store or the junk yard first!:whistle::)
  18. Farmchuck
    Farmchuck
    Nepa
    :binoculars:
    I don’t know where the BBC came from in the above post. Guess I need to double check before posting :picard:
  19. Gourley
    Gourley
    LaPorte, Indiana
    I use one like this.
    Good for moving wood in the snow plus I can fit in it with all 3 kids to fly down a hill.
    Horkn, Backwoods Savage and Chvymn99 like this.
  20. Backwoods Savage
    One can also use larger logs for the runners and can also fasten on some wide boards under the runners or any steel or aluminum fastened onto the runners, etc. Use your imagination.
    EODMSgt, Horkn, Mag Craft and 4 others like this.
