Beginner question sort of
Discussion in 'Chainsaws and Power Equipment' started by JW IN VA, Feb 14, 2020.
  1. JW IN VA
    JW IN VA
    Virginia mountains
    I should know this ,but.
    Will going from an 18" ar to a 16" bar make any difference when you are only cutting 12"-14" diameter or less?
    Seems like it shouldn't matter.
  2. Eric VW
    Just have to bend 2” further. :hair:
    Good reason to go with a 20” bar :yes:
    (Depending on the saw, of course)....
  3. JW IN VA
    JW IN VA
    Virginia mountains
    Thanks. That's what I thought but I wanted to be sure.I'd run a 20" if I could get one.Oregon only goes to 18" for my model.
    .325 pitch and.063 groove
  4. Farmchuck
    Farmchuck
    Nepa
    You’ll sharpen the 16” a tad bit faster
  5. Holland Dell
    Holland Dell
    SW Wisconsin
    What saw are you putting this on?
    Screwloose and Backwoods Savage like this.
  6. Fifelaker
    Fifelaker
    Fife Lake Mi.
    Going from an 18" to a 16" will gain a little bit of oomph due to the chain dragging on the bar and it will oil a bit better.
  7. Dumf
    Dumf Banned
    Maine
    Go with shorter bar JW. Now that you're into 4 score plus years, shorter means less strain, easier sharpening.
    Forget the " 2" bending" with a longer bar. Use a log hook or other tool to raise the log for bucking anyhow.
    Besides, there is a loss of torque and power with longer bars. Learn to bore or plunge cut safely for trunks thicker than the bar.
    It's fun to plunge that sharp chain ( need sharp for this ) straight into a trunk on both sides. Many videos and experienced users around to show you how.
    Screwloose likes this.
