Absolute steel automatic dampers?
Discussion in 'Modern EPA Stoves and Fireplaces' started by tim117, May 3, 2019.
  1. tim117
    tim117
    Mount Laurel, South New Jersey
    hi all, I’m thinking about getting one of these. Can someone who has one please explain the automatic damper?
    I’m concerned about how safe that is.
    I’m other words, if I left the stove burning while I’m at work, could it run away on me and over fire?
    Thanks
    Chaz, In the Pines and TurboDiesel like this.
  2. TurboDiesel
    there is a bimetal tab on the back of the stove that lets air into the secondary air.
    its only about a 1x1 opening.
    not much air to let the stove "run away".
    everything else is manual...
    unless you have an unusual amount of draft, i dont see you having a run away fire.
    papadave, Chaz and In the Pines like this.
  3. brenndatomu
    Many many people leave totally manual stoves run while they are gone...it's just a matter of learning to run the stove and how it reacts in your install...so with a bimetallic spring control, the AS should be even better left unsupervised...
  4. bushpilot
    bushpilot
    Eastern Washington
    ^^^ Yep, what these guys said. ^^^
    My totally manual stove doesn't cause me a moment of worry when I leave it (or when I sleep), because I know how my installation behaves.
  5. tim117
    tim117
    Thanks for elaborating on that for me. I’m okay with leaving my manual stove cause I know how she behaves. The idea of a stove changing how much air it’s taking on its own scared me.
    brenndatomu and Chaz like this.
  6. Mwalsh9152
    Mwalsh9152
    Pelham NH
    Is the automatic damper a new option on the AS? First I've heard of it.on one.
    brenndatomu likes this.
  7. Canadian border VT
    IS has bi metallic damper also, I leave it, no worries!
    brenndatomu and tim117 like this.
  8. Flamestead
    Flamestead
    Windsor County, VT
    Not a new option. These aren’t the primary air supply being auto-dampened, it is fine tuning to ensure complete combustion.
  9. Highbeam
    Highbeam
    Some straight noncat stoves use a similar auto damper for secondary air too.
    tim117 likes this.
