272 switch not working
Discussion in 'Chainsaws and Power Equipment' started by Chud, Mar 20, 2022.
  1. Chud
    Chud
    NC
    If the wire is attached and it doesn’t work, does that mean the switch is bad, or is there something else I need to check?
    M2theB likes this.
  2. trapper brad
    trapper brad
    Arkansas
    Ohm out the switch and that should tell you.
    M2theB likes this.
  3. M2theB
    M2theB
    Central Massachusetts
    How does it not work? Won’t start or won’t shut off?
  4. Chud
    Chud
    NC
    Won’t shut off
    M2theB likes this.
  5. M2theB
    M2theB
    like trapper brad says, check resistance across the poles on the switch in the on position and the off. On should be high number, like infinity. Off should be a dead short. If it’s not that way the switch doesn’t have a path to ground. Is the little screw that connects the switch to the case still there?
    MikeInMa likes this.
  6. Chud
    Chud
    NC
    I’m not near the saw atm, but I assumed it pops in and out like most old Husky switches. I have a spare switch I can try. I’ve encountered this a few times but it was a broken or disconnected wire that prevents ground.
  7. Chud
    Chud
    NC
    272xp update :yes:
    Replaced the switch and problem solved.
    The switch does have a screw and it was there.
    I had an extra switch that I bought for a 288
  8. trapper brad
    trapper brad
    Arkansas
    Good news. Saw on brother
    M2theB and Chud like this.
