2 Differents Things
Discussion in 'Modern EPA Stoves and Fireplaces' started by MightyWhitey, Dec 14, 2018.
  1. MightyWhitey
    MightyWhitey
    1. Do any of y'alls stove pipe screws "back out" on their own??? I'm guessing it's a heating/cooling thing.
    2. Do any of y'all with Englander stoves have issues with the "hinge pins' working their way UP?? Almost to the point of not being "hinged" any longer.
  2. Chvymn99
    Hinge pins work up time to time... either use my knife or the handle to the ash scoop to knock it back down...
  3. HDRock
    It wasn't an englander but my old stove did that all the time
  4. Horkn
    Same thing on my quadrafire, and the lopi we had up at the cottage did the same as well. That's just a thing that happens,
  5. Screwloose
    Screwloose
    Different stove but yep.
  6. bushpilot
    bushpilot
    Eastern Washington
    Yep on the pins, nope on the screws.
  7. yooperdave
    One set of pins on my 13 did work itself up. My son noticed it a couple years back or so. Added a small amount of wd, tapped it back down and it has never recurred.
    As far as the stove pipe screws backing out, no and I haven't heard of that one. I do use sheet metal screws so maybe that is why?
    And maybe you have one of those hair dryer type fans on the stove? Maybe that likes to loosen things up!
  8. MightyWhitey
    MightyWhitey
    Thanks y'all!!
    I'll try a bit of "lizard pizz/WD40" next time.
    The stove pipe screws................the ones that back out, will not tighten once bottomed out. I may need a larger diameter screw.
  9. Backwoods Savage
    Never had the screws work out but then we usually put a dab of cement on them before screwing them in. Not entirely necessary but have always done that.
    Hinge pins do tend to work their way out from time to time but its not a big problem.
    Chaz and In the Pines like this.
  10. chris
    chris
    SE WI
    Had to make a new set for one stove, became to loose and would not close tight even on new gasket. took a couple tries on the lathe to get the taper just right, it isn't very much couple thousandths
  11. In the Pines
    In the Pines
    my napoleon top hinge worked itself up a little bit but hasn't moved since.
    The bottom is still seated. I never bothered with the top one so long as it doesn't move up anymore.
    My screws have not needed any attention since the install 6-8 years now.
    Sure doesn't seem that long ago now..
    Chaz likes this.
  12. chris
    chris
    SE WI
    Well it's nice to know you don't have a screw loose:rofl: :lol:
