TSC Log Trolley
Discussion in 'Axes, Mauls, and Hand Saws' started by Kimberly, Feb 13, 2020.
  1. Kimberly
    Kimberly
    The Kangaroo State
    Does anyone have one of the TSC wood trolley? They are currently on offer. At the moment I load the wheelbarrow and push it to the door, then I have to make several trips back and forth to fill my rack at the stove. I was thinking with this trolley I could roll it into the house; I have a few steps to navigate. The wheels look a bit cheap though; looks like plastic centres.
    Mag Craft, JB Sawman, Chaz and 4 others like this.
  2. Aje1967
    Aje1967
    Kenosha, Wisconsin
    Have never seen one. The idea is solid. Have to check it out in person and see what you think of the wheels. They would not get too many miles on them.
    JB Sawman, Chaz and Stlshrk like this.
  3. Stlshrk
    Stlshrk
    Central Virginia
    Kimberly , it looks similar to a hand truck that I modified for my purposes. I think the position of the wheels of the TSC unit would make it a bit easier to handle when full. But, I don't know how well the plastic wheels would hold up.
  4. Kimberly
    Kimberly
    The Kangaroo State
    I decided to look on Amazon and found several with the pneumatic wheels that I like better. There is one that I am considering getting and I have a $10.00 credit on Amazon as well. I thought about building a box to sit on a hand trolley/truck but my current one needs repair. Maybe it would be better to invest in a new hand trolley with a box; a ratchet strap would hold the box in place. When I needed the hand trolley I could remove the box. That way I have two tools in one.
    JB Sawman and Chaz like this.
  5. TurboDiesel
    Look at the Plow and Hearth brand.
    The bigger wheels are MUCH better!
    JB Sawman, Chaz and yooperdave like this.
  6. yooperdave
    OK, C'mon now. You two have to get on the same page. :picard:
    Either it's "hand truck" instead of trolley or "plough" and hearth. :rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
    Chaz likes this.
  7. yooperdave
    With the use being outside, larger wheels (tyres?) would be to the advantage of one, right?
    Chaz likes this.
  8. Kimberly
    Kimberly
    The Kangaroo State
    I think the softer pneumatic tyres would be easier on my vinyl flooring as well; I want to be able to wheel the wood inside.
    JB Sawman likes this.
  9. Kimberly
    Kimberly
    The Kangaroo State
    Yes, I see what you mean.
    JB Sawman, farmer steve and Chaz like this.
  10. Kimberly
    Kimberly
    The Kangaroo State
    I have changed my mind on the TSC; there are a lot of choices on the market that I think are better. However, I do like the idea of a hand trolley to bring the load of wood inside all at once instead of making several trips with my arms full.
  11. Kimberly
    Kimberly
    The Kangaroo State
    I checked the prices on these on Amazon and they are not in the budget.
  12. farmer steve
    farmer steve
    top of the hill york co. PA.
    I delivered wood to a lady that used one of those years ago. Only thing was that it was about an inch wider than her door frame and she had big gouges in the frame from the axle ends.:jaw: It worked good though
  13. MikeInMa
    I have and use that style of log dolly. Got it second hand off Craigslist. I like it.
  14. JB Sawman
    JB Sawman
    pennsylvania
    I guess the first trip through the door was a little rough after that it went easier ??:rofl: :lol:
  15. Kimberly
    Kimberly
    The Kangaroo State
    I found this one on Amazon and it is only 13 inches wide so will better fit the shorter wood that I cut; the width from outer wheel to outer wheel is not shown. My concern is how strong is the tubing? It does state that it can hold 220 lbs of wood.
  16. WeldrDave
    The problem with them is the "tires"! Bastards go flat and don't hold up well! They are made in china and made from recycled soda cans. "My opinion" get a good heavy duty hand truck and bolt a big basket to the bottom blade.
    yooperdave and JB Sawman like this.
  17. Kimberly
    Kimberly
    The Kangaroo State
    Yes, been thinking about that as well; a wooden crate and I could just use a ratchet strap to hold the crate to the trolley when I need to bring in the wood.
    blacktail and WeldrDave like this.
  18. JB Sawman
    JB Sawman
    pennsylvania
    Hey Kimberly the tubing on those is paper thin a customer brought me one to fix it snapped at that bottom bolt hole those kind of tires are terrible if you do get something put tubes in the tires right away then you should not have any trouble I will show you my " Trolley" for bringing wood in :Dbut I think it would be a little rough on your living room floor just thought you would get a laugh :rofl: :lol: JB DSCN0318.JPG DSCN0318.JPG
  19. JB Sawman
    JB Sawman
    pennsylvania
    WeldrDave if you ever want a laugh hold one of those tires up to a good light you can see through some of them:rofl: :lol: JB
    WeldrDave likes this.
  20. WeldrDave
    That's what I'm talking about!!! :yes:
    yooperdave likes this.
