Square filing chains
Discussion in 'Chainsaws and Power Equipment' started by mdavlee, Aug 17, 2014.
  1. Kyle Mulligan
    Kyle Mulligan
    North Greenbush, NY
    I want to thank mdavlee and SquareFile for there contributions to this thread. I started to square file a few weeks ago. I am on my 3rd chain and have had very good results with the first 2. They sure do not look like yours but they cut well. These will be work chains. I have been filing corner to corner and I get into the strap pretty hard. From what I read this is fine. Out of the 3 chains the first was factory square, the second was full chisel round and this one is semi chisel. The semi seems much harder to file the top plate, working corner and side with one file angle. Any tips on what angles to use? IMG_2753.JPG IMG_2749.JPG
  2. Redfin
    Redfin
    central Pa
    Ive never seen a semi chisel filed square. Does it end up with two points at the corner?
  3. concretegrazer
    concretegrazer
    Southwest MO
    Cut4fun has mentioned it being done to 3/8 lp before ps came out. Curious to where you'd put the corner.
    definitive dave likes this.
  4. concretegrazer
    concretegrazer
    Southwest MO
    Been playing around with a triangle style file.
  5. Kyle Mulligan
    Kyle Mulligan
    North Greenbush, NY
    The corner is coming out smudged. The corner is not getting crisp. I worked on it for and hour last night and could not get it right. The top plate was not getting sharpened at the angles I was using. I had to drop the angle down and the corner wasn't getting crisp. I think I have to take the cutter back more because the working corner seams to be thicker. Or maybe semi won't be any good to make square.
  6. Kyle Mulligan
    Kyle Mulligan
    North Greenbush, NY
    That is a great pic! What camera do you use?
  7. concretegrazer
    concretegrazer
    Southwest MO
    Thanks, just took it with my phone & brightened it with an app.
    Shawn Curry and definitive dave like this.
  8. Redfin
    Redfin
    central Pa
    Ive thought about filing semi square but just didnt see a benifit. I think Ill try for myself just to see it.
    Moparmyway and definitive dave like this.
  9. DexterDay
    DexterDay Administrator
    Northeast Oh
    Great pic!!! Looks like it should cut great!!
  10. concretegrazer
    concretegrazer
    Southwest MO
    Don't know. I don't have a bar for it.
  11. jo191145
    jo191145
    Ct
    Could this be done with a square diamond blade on a standard chain grinder or are the angles too complex?
  12. mike bayerl
    mike bayerl
    I accidentally sent some Woodland Pro semi chisel to to be square filed. It's came out "interesting", but it chews through wood like and angry beaver.
    Cold Trigger Finger likes this.
  13. SquareFile
    SquareFile
    somewhere
    On a standard round grinder the wheel comes to the cutter. On a square grinder the cutters comes to the wheel. The answer to your question is no.
    Hedgerow, DexterDay and jo191145 like this.
  14. 94BULLITT
    94BULLITT
    Frederick County, VA
    I'm getting interested in square filing again. How is this looking? I know the gullet needs cleaned up.
    Nixon likes this.
  15. concretegrazer
    concretegrazer
    Southwest MO
    Your a little low in the corner.
    Moparmyway, Nixon and 94BULLITT like this.
  16. 94BULLITT
    94BULLITT
    Okay, I'll redo it.
    Moparmyway and Nixon like this.
  17. Nixon
    Nixon
    West Sunbury,Pa .
    Go ahead and run it . You're a tad low on the corner ,but it will still cut . It will just likely dull a bit quickly . Make your adjustment on the next sharpening session .
    concretegrazer and 94BULLITT like this.
  18. 94BULLITT
    94BULLITT
    I only did one on that chain.
    I did another one. There is a little chrome on the side that got pushed over. I should have taken a wire brush to it before taking a pic.
  19. concretegrazer
    concretegrazer
    Southwest MO
    Looks good.
  20. 94BULLITT
    94BULLITT
    Awesome, now I need to duplicate that on all the other cutters.
    Moparmyway and concretegrazer like this.
