  1. mattjm1017
    mattjm1017
    Hello Pellet people Im considering getting a pellet stove for my finished garage/laundry room its a little over 400sq ft with 10 ft ceilings. Im wondering if yall have any recommendations for a small pellet heater to heat that area without driving everyone out from being to hot. I am also thinking that I will open the door going into the house and that could let some heat into the kitchen not that it needs it really my only goal is to heat the garage area.
    savemoney likes this.
  2. DexterDay
    DexterDay Administrator
    Northeast Oh
    Because its a garage? You may want to contact your ins agent. Some will allow it, but it will have to be on a raised Hearth around 18"-24" off the ground? (IIRC? )
    Any smaller stove that will auto ignite and run on/off will work. This means that when the stat temp is reached, it shuts down. When temp drops and Stat call for heat, stove starts.
    Some nice smaller units are
    Quadrafire Santa fe
    Quadrafire Castile
    Quadrafire Classic Bay 1200
    Enviro mini
    Englander 25-EP
    Englander 25-PAH
    Englander 10-CPM
    Heatilator PS-35
    Heatilator PS-50
    Harman P 43
    Harman Advance
    Many others out there. .
    Russell and mattjm1017 like this.
  3. slvrblkk
    slvrblkk
    Northampton, PA
  4. mattjm1017
    mattjm1017
    We call it the garage but its been converted/finshed its no longer a garage good idea checking with the insurance people though especially since Ill have to run a chimney and everything for it.
  5. DexterDay
    Northeast Oh
  6. imacman
    imacman
    Denver, NC
    As mentioned above, a refurbed Englander 25pdvc, or an Enviro Mini.
  7. DexterDay
    Northeast Oh
    PDVC isn't on /off? For a little more, you can have a newer generation PAH, EP, CPM, Or IP
  8. imacman
    imacman
    Denver, NC
    Only single auger stoves do both. But those other stoves will "bake" him out of that small room, as you said.
    I'd suggest the Mini...rated at 600 - 1200 sq ft
  9. DexterDay
    Northeast Oh
    I know only Single augers do both. Have had 2 PDV's.
    That's why i questioned the suggestion of the PDVC twice? High/Low only should not be suggested, as 400 Sq ft (even if it was leaky) is to much. On/Off only with High/Low option is best. Which takes PDVC and PDVC off the list.
    Unless he wants to shut it down and start it up a lot.
    Op- Have you checked your local CL? Anything in the 30,000-45,000 BTU with the ability to start up and shut down on its own .
    smoke show likes this.
  10. krooser
    krooser
    Waupaca, WI
    Get a PDVC and an open window….
    slvrblkk likes this.
  11. jtakeman
    Mini or the Empress get my vote. Both are very quite too!
  12. IHATEPROPANE
    IHATEPROPANE
    St Croix Lancaster is a nice little stove
  13. don2222
    don2222
    Salem NH
    Hello
    I have a Harman P61a-2 with Selkirk DT venting in my converted garage. It is Auto-On/Off plus ramps the fire up and down to keep the room temperature automatically. I got it used. The seller wanted $250 and I talked him down to $225. :) All it needed was a new convection blower, a hopper lid latch, a new circuit board, a new ignitor, a complete paint job and a new black fire door. I also got the newer ash door and ash pan plus I just scronged a nickel tile frame. Also built a raised hearth with pressure treated lumber and waterproof composite trim with porcalin tile over cement board with a 3/4 inch plywood for strength. I painted some old brass louvre chrome. Now all I need is a nice scenic tile. :) It was definitely worth it!
    Click pic to enlarge.
  14. slvrblkk
    slvrblkk
    Northampton, PA
    Holy cow...Don what do you have wrapped up in that thing with all those parts? What happened to it with the previous owner that it needed all that?
  15. subsailor
    subsailor
    Winthrop, Maine
    Don, did you read the thread title? How does a P-61 work it's way into a thread about a small stove. Yes it has auto On/Off, but in 400 sq. ft. it would be 95 degrees before the stove finished starting up!
    343amc, imacman and JRSDWS like this.
  16. mattjm1017
    mattjm1017
    What are all these abbreviations? PDVC PDV PAH, EP, CPM, Or IP? Im a little lost with those but any way Im going to look around on CL and see what I can find Im in no hurry this will probably be done over the spring and summer Im just trying to get some ideas right now. I looked at the Enviro Mini and keep coming back to it as it seems to be the smallest out there and I like the controls on it with the auto on off. I also need to check with my ins company to see if they will allow it.
  17. subsailor
    subsailor
    Winthrop, Maine
    Most if not all of those initials are stove model numbers from England Stove Works. I not up to date on their models, so can't say they all are.
    mattjm1017 likes this.
  18. DexterDay
    Northeast Oh
    Those are all Englander model #'s. That's exactly what they are called. They mean something for all models. I only know a couple (EP= Evolution Pellet). But they only use the letter designation.
    25-PDVC (not recommended)
    25-PDV (not recommended)
    These would all work below
    25-EP (beautiful unit)
    25-PAH (Big hopper, but looks like a box)
    10-CPM (Pretty stove, and Multi fuel unit)
    25-IP (Modern styling and there latest unit)
    Quadrafire makes an awesome stove for on/Off only, as does Hearilator. The Heatilator can be had for around $1,500 new (PS-35 a Lil less, the PS-50 a Lil more).
    The Mini is an awesome unit. If you can find a used one? I'd go with that.
    mattjm1017 and subsailor like this.
  19. imacman
    imacman
    Denver, NC
    I have a friend that had one.....quietest stove I saw. On low I didn't even know it was running. He used it in a sun porch which was about 15' x 20', and let the excess heat go into the house. He loved it, and it was his first pellet stove.
  20. krooser
    krooser
    Waupaca, WI
    How about a Rocket Stove fed by pellets?…. you can build one yourself out of scrap metal…
