High moisture meter readings?
Discussion in 'The Wood Pile' started by DNH, Sep 11, 2017.
  1. DNH
    DNH
    Missouri
    Getting some unexpected high moisture reading with my harbor freight MM, 9 month CSS walnut mid 20's to mid 30's, Oak last fall read at 31%, mid 30's now. Mulberry CSS for 17 months reading mid 30's! These were all fresh splits, temp in the low 70's.
    I know the walnut will burn but I really wanted to use up the mulberry and get it out of my way. Would a solar kiln do any good for 2-3 months? Or just let it set another year?
  2. Horkn
    How accurate is your HF mm? Have you ever tested it against a different mm?
    Also, super fresh , wet cut green wood can read abnormally. As in, not accurately.
    p61 western and Ralphie Boy like this.
  3. Eric VW
    Oak readings sound about right...
    What's your layout for you stacks? Full sun and breeze? Shaded?
  4. HDRock
    Are you sure you have the meter set to Wood mode ?
  5. DNH
    DNH
    Missouri
    MM reading INCREASED from reading 10 months ago on my oak and mulberry! Everything is CSS double rows on individual pallets set on concrete blocks to provide air flow. Depending on the stack 1/2 to all day sun, plenty of wind.
    I'll try a piece of scrap pine lumber to see what it reads.
  6. Backwoods Savage
    Another good reason to get onto the 3 year plan. Then you can just throw that MM away. We've burned wood over 60 years and have never seen a need for one. I like it that way.
  7. DNH
    DNH
    Missouri
    Last spring I made it to the 2 year plan, January-February I made it to 3 year plan CSS. I have close to another years supply in rounds and logs waiting on cooler weather to CSS, then I get to cut some more that will have me to 4-5 years ahead.
    The MM is more for fun, to see how the different species season at different rates and to guide in what I burn until everything is 3 + years seasoned!
    clemsonfor, Eric VW, Horkn and 3 others like this.
  8. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Walnut can be tricky, it does the sponge thing in my past experience. Mulberry is a deceivingly dense wood. You would think otherwise how it grows like a weed but thwre are serious Bus there. Too cover and gibmve it another year..... or stack by the stove for a few days, it's get crispy dry that way.
    p61 western, Eric VW, Horkn and 2 others like this.
  9. Backwoods Savage
    Glad you are on the plan!
    Eric VW likes this.
  10. Boomstick
    Boomstick Banned
    Saratoga county ny
    How are you testing the wood? It should be split and taken from the center.
    Moisture meters loose accuracy at higher mc.
    You can test it on a phone book(if you can find one) should be close to 8%.
    I have two HF mms and they match each other even after leaving one outside in the rain:hair: couldn't find it so I bought another:rofl: :lol:
    clemsonfor, Eric VW, papadave and 2 others like this.
  11. HDRock
    Good idea
    If you press into the palm of your hand it should be around 35%
    p61 western, rdust, Eric VW and 2 others like this.
  12. HDRock
    Oh yeah another thing on the Harbor Freight meter, if the battery's Get Low you will get screwy readings
  13. Horkn
    True, a MM can be for fun, but the only way to know the actual MC of wood is to use a moisture meter, regardless of whether it's seasoned for 5 years or 5 minutes.
  14. HDRock
    X2
    Eric VW and Horkn like this.
  15. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    The burninator knows..... The burninator ALWAYS knows.
  16. amateur cutter
    Throw a couple splits in a campfire & see if they sizzle. As stated Walnut can be a pain to dry. I give mine 2 years. I have a hard time believing the MC is higher than a previous reading. I'd bet the Mulberry is ready to go unless it was in the shade in a no airflow area.
  17. Eric VW
    Well, it's obvious what the issue is... someone has either pp'd on yer wood or, soaked it with beer. What other explanation could there be?!
    :whistle:
    :handshake:
  18. BDF
    BDF
    Depending on how deep you press it in, right? I mean if the probes go through, the reading will start to drop again.....
    Brian
    Horkn, Eric VW and HDRock like this.
  19. DNH
    DNH
    Missouri
    Reading low to mid 20's on the palm, pine 2x4 split reading 10-12%
    amateur cutter ill try the camp fire and see how the mulberry burns, it's been setting by the garden so 8+hours of sun per day CSS since April 2016 I also have a hard time understanding this increase in MM
  20. HDRock
    Yup, probably get a high reading if you strike blood :hair:
