Has anyone Switch from Wood stove to Pellet Stove
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by KatwillNY, Jul 20, 2014.
  1. KatwillNY
    KatwillNY
    After having had some issues with my prostate last fall I am finding it more and more difficult to process wood, which really annoys me since I really enjoy the activity. We currently have a Pellet stove and a wood stove. I am thinking of switching out my Englander NC30 for a Summers Heat of its equivalent from HD. My NC 30 is currently attached to a class A 18 feet class A outside and a 4 feet going into a 90 degree double wall pipe inside. Would i need to replace the existing pipe or can I use an insert (3 or 4 inches) to go inside the Class A? by the nature of my question I'm sure most can discern I wont be doing this job myself. LOL.
    thanks
    Franklin
  2. smoke show
    smoke show
    Pittsfield, Wi
    Pellet vent can be adapted to class A rather easily.
    RockyMtnHigh, will711 and jtakeman like this.
  3. jtakeman
    Hi KatwillNY,
    Pretty sure most pipe manufacturers have adapters to connect pellet vent to class a piping. Simpson duravent(pelletvent) has one for both 6 and 8 inch stove pipe.
    will711 and smoke show like this.
  4. subsailor
    subsailor
    Winthrop, Maine
    I have the adapter pictured above to convert my 3" pellet pipe to 6 " stove pipe on my Summer's Heat PDVC. The adapter connects at the stove. Virtually a 2 minute job to adapt from 3" to 6 or 8"
    smoke show likes this.
  5. chris
    chris
    SE WI
    Be careful when doubling the size of a flue can lead to creosote problems as well as draft even with a pellets stove forced draft system.
  6. nate
    nate Banned
    Palmer, AK
    Buying firewood isn't an option where you live? I'd imagine it'd be cheaper than pellets.
  7. Lousyweather
    Lousyweather
    yea, all of the above....you can adapt over easily, it should work fine.....evenso, Chris's mention above is valid.....you will still need to clean your chimney and be cognizant that you can still get creosote with an improperly burning pellet stove......some burn more proper than others, and that's all I am saying!
  8. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    I prefer when possible to run the pellet vent all the way through the class A if it's a straight run. It makes cleaning easier.... I ditched my woodstove for a pellet stove and haven't regretted it one bit. It has cost me a LITTLE more during the cold months for the fuel (I was paying for wood).
    If I was retired and could be home to feed the woodstove all the time, I would have stayed that way but being a blue collar chap, I love having a stove that feeds itself.
    wildwest likes this.
  9. wildwest
    Wyoming high plains
    Can you tell me what "class A" means?
  10. jtakeman
    Here something I found on the web. Should help some?
    More can be found here at this link. or on the web.
    http://www.highschimney.com/articles/types-vents-type-vents-chimney-guide-vents/
  11. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    Class A chimney is what you use any time you pass through a combustible surface ie: a ceiling, a wall, or anything that can burn. Even in a metal building it is what you use to penetrate the roof etc., if done to code.
    Oh and the important part, it's made for wood burning appliances
    Lousyweather and wildwest like this.
  12. wildwest
    Wyoming high plains
    Thank you for the informative posts! I have alot to learn....One masonry chimney to reline, and another one that should be class A but not sure I can call it that since we will be lining the existing older wood stove pipe.
  13. Lousyweather
    Lousyweather
    buut, actually, Class A can also be used for pellets, oil, and coal as well........
    RockyMtnHigh and wildwest like this.
  14. nate
    nate Banned
    Palmer, AK
    Question. Is class A normally double or triple wall?
    Around here it's called Metalbestos.
  15. Lousyweather
    Lousyweather
    Metalbestos was actually a brand name, for the Selkirk company....arguably the largest seller of class A and other products......Metalbestos had two walls, the annular space filled with a insulation
    Class A can be either 2 or 3 walls
    savemoney and jtakeman like this.
  16. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    Agreed
