Doin some splittin with my new milk crate
Discussion in 'The Wood Pile' started by HDRock, May 27, 2015.
  1. HDRock
    Just kiddin, I already had the milk crate.
    New to me is this puppy, I got it off craigslist today :D:axe::rootintootin:
    I took a pic of the pile of splits and the log catcher installed on the splitter but it didn't take I guess .
    Is cotton wood normally stringy as hell ??
    Stinny, wildwest, Gark and 16 others like this.
  2. Ashwatcher
    Ashwatcher
    West By God Viginia
    Nice score, but where's the puppy?
  3. Horkn
    There's been some nice off season splitter deals recently.
    It looks really nice.
  4. Ashwatcher
    Ashwatcher
    West By God Viginia
    Looks brand new---hope you got it sweet-One thing I like for sure is that handle on the tongue---my new Cub doesnt have one and it is not easy to move around once off the concrete---what kind of engine is on it?
  5. Deacon
    Deacon
    Eastern Nebr.
    Should be a great splitter for you. I ran a 25 ton Huskee for about 15 years.
    Only problem I ever had was a flat tire... Probably my fault, trailing to fast.
    Added a spare tire.
    Cottonwood can be very stringy. Heavy when wet & LIGHT when dry.
    Burns hot & fast.
    :sherlock:
  6. HDRock
    Yeah I have been seeing a lot of splitters I was interested in but,, they were one two three hour drive away this one was only 15 miles away.
  7. HDRock
    Briggs and Stratton engine, it's less than 2 years old
    The guy said he only used it 4 times and I believe it, he had less than a third of a cord of wood by his garage.
    He thought he was going to get a lot of wood from his tree service buddy but never got any, so, decided he should sell it because he didn't use it.
    The handle is nice I guess but I thought this thing would be better balanced then it is. its heavy
  8. Ashwatcher
    Ashwatcher
    West By God Viginia
    His loss, your gain hopefully-doesnt sound like he was hoarder minded-glad you benefitted from it-Keep it horizontal and enjoy...:smoke:
  9. markr
    markr
    ohio
    Great score. Just cant afford to pull the trigger on one. Can rent a 32 ton from local rental place for 75 bucks for a full weekend. And if it breaks down he brings me another one. Rent 2 or 3 times a season. Cost effective for me.
  10. HDRock
    Yeah I had a couple of large ones there I split up vertically just because I could after that I put it horizontal and did the rest, but I have some big white oak I will be busting up vertically
  11. HDRock
    Nothing wrong with that.
    I'm not fond of doing marathon work, just work at my leisure when I want.
    Stinny, Backwoods Savage and Horkn like this.
  12. Horkn
    That's how I work too.
    Backwoods Savage, Eric VW and HDRock like this.
  13. bogydave
    Nice addition to your "ever growing", wood gathering tool box ! :yes:
    Cottonwood here not very stringy
    Usually splits easy.
    Stinny, Eric VW, Horkn and 1 other person like this.
  14. HDRock
    the Cottonwood was like a yard bird so maybe that's why it is so stringy.
    How hot is the cylinder on the splitter supposed to get?
    I could hold my hand on it
  15. Ashwatcher
    Ashwatcher
    West By God Viginia
    That would be about right HDRock-shouldn't be any warmer than that-and my latest "yardbird" maple was tougher than woodpecker lips
    Stinny, Horkn, HDRock and 2 others like this.
  16. HarvestMan
    HarvestMan
    Southeastern Michigan
    That is a great rental rate. I've been checking and have not found anything that good here. I just can't pull the trigger and buy one; I've decided I need to rent one first and give it a try. Getting too hot here, so will likely rent one this fall and give the hydraulic club a test drive to see if I want to become a full time member.
  17. Iceman7668
    Iceman7668
    Indiana
    I have my buddies 20 ton mtd at the house. I cut a crap load of wood and it is nice to have. He has an outdoor burner so he gets all the uglies and I cut a lot of his wood. This way I can keep his splitter here in the garage and use it when I need it. If he takes it back I will have to get my own!
  18. bogydave
    The harder you work it the hotter it'll get.
    It's oil, so it can get pretty hot (300° range) & still be OK.
    Friction thru the pump & valve generate heat.
    Mine was pretty warm (120° maybe, so 100° raise in temp over ambient) after a couple cords last Oct, but it was 20° out.
    It has a pretty big tank, so should have no problems of overheating.
    Stinny, Horkn, Ashwatcher and 2 others like this.
  19. Eric VW
    With age comes wisdom.....:eek::thumbs:
    But you ain't aged....
    My Champion 22T gets to pretty hot if I run it for more than an hour or so... Depends too on what I'm splitting- tougher, stringier, knotty stuff gets things cooking quick in the warmer months- even had some foaming outta the tank cap a few times- shut it down and cool myself off with some stacking.... of empty cans!
  20. Backwoods Savage
    Cottonwood will be stringy at time while others won't be stringy at all. You take what you get there.
    That thing does look like new. Nice find HD.
