Can of whoop ash and a mill =
Discussion in 'The Sawyer Room' started by The Wood Wolverine, Feb 8, 2016.
  1. The Wood Wolverine
    Don't be sorry! I'm a relative newb so I heed good advice. And btw... the rain in Spain falls mostly in the plain. rofl ;)
  2. 1964 262 6
    1964 262 6
    williamsburg, ohio
    that is the coolest thing! i had no idea , milling rocks. how many cuts on a chain before it gets sharpened?
  3. The Wood Wolverine
    The 30" wide stuff, 2 cuts and I notice it going a bit slow, but I cut 3 slabs. Only required 2 light strokes on each cutter to get it back. The last stuff I posted I did the entire base with one refresh, so about 5.
  4. 1964 262 6
    1964 262 6
    williamsburg, ohio
    i want to do this !
  5. g60gti
    g60gti
    NY West
    Excellent work, I am very envious. So many great projects you could make with that. Quick question for those in the know. How are you drying the slabs? I had a 26" white oak trunk that I cut into 3" thick cookies and wanted to try and make some table tops out of them. After I cut them I soaked them with linseed oil and put them in my garage rafters with spacers between them for air flow. I just checked them and all three of them have huge cracks 3-5" in them, pretty much unusable. Maybe the heat and humidity was too high up there over the summer months and they dried out too fast? I would love to get a simple Alaskan mill and mess around with making some lumber but don't want to put in the work just to screw it up again.
  6. FatBoy85
    FatBoy85
    Washington State
    I did this for cutting boards from black locust too. Maybe try the mill way and not cut cookies but a couple slabs for butcher block.
  7. FatBoy85
    FatBoy85
    Washington State
  8. TurboDiesel
    Hey Jason
    Wondering if these slabs ever turned into projects? Or profits?
    Or still ....drying? ;)
  9. The Wood Wolverine
    Still sitting in the same place, covered with rubber roofing material. I'm sure as dry as they will get by this point. I just found an idea to use the other day on ope. I'm considering a couple of these. If you would want some of it, lmk.
    WESF, T.Jeff Veal, JB Sawman and 7 others like this.
  10. buZZsaw BRAD
    Thats cool. Whats species?
  11. The Wood Wolverine
    Not sure. One of the guys on OPE built it and shared the pic.
    T.Jeff Veal and Chazsbetterhalf like this.
  12. buZZsaw BRAD
    Just read through the whole thread. That was one heck of a tree to mill especially with a chain saw. Buzz-saws mill can take up 18-20" logs.
  13. buZZsaw BRAD
    All ive "made" out of milled wood so far. Cull 4" thick BL slab (center checks) on two BL stump cut offs. IMG_5763.JPG
  14. JB Sawman
    JB Sawman
    pennsylvania
    Yes the excessive heat in a garage rafter would be a good reason but white oak always checks when drying and as to all milling messing up is how you learn what to do or not do and wood will always do something different to mess with you JB
  15. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    On a stob like that. Put a really deep face in it. They tip over easier. 2/3
  16. T.Jeff Veal
    Just read the thread. Excellent work, my friend
